はじめに
If the volume knob on your soundbar isn't working, you may want to replace it. This guide should help you do that.
必要な工具と部品
Use a Jimmy to peel off the screen stuck to the front of the speaker.
Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
Apply a light downward pressure on the circuit board next to the volume control.
While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
