メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Debadging a Ferrari
必要な工具と部品
ビデオの概要
    1. Debadging a Ferrari, Find and remove any bolts: 手順 1、 2の画像 1 Debadging a Ferrari, Find and remove any bolts: 手順 1、 2の画像 2
      • Depending on the model of Ferrari you own, you may need to remove several bolts that hold the badge in place.
      • The badge that is being removed in this tutorial is from the Ferrari 458's front passenger side, and the bolts can be found underneath the inner wheel well.
      FixBotに聞いてみる
      コメントを追加
    2. Debadging a Ferrari, Line the badge with masking tape: 手順 2、 1の画像 1
      • Line the badge of your Ferrari with masking tape as shown.
      • This is done to protect the surrounding paint during the removal process.
      FixBotに聞いてみる
      コメントを追加
    3. Debadging a Ferrari, Soften your adhesive with the heat gun: 手順 3、 1の画像 1
      • Warm up the badge using your heat gun.
      • Take care not to over heat the badge! You're only softening the adhesive underneath the badge, not cooking it.
      • Think of how warm the exterior of a car gets when it sits out in the sun during the summer. That will act as your reference point.
      FixBotに聞いてみる
      コメントを追加
    4. Debadging a Ferrari, Cutting your adhesive: 手順 4、 2の画像 1 Debadging a Ferrari, Cutting your adhesive: 手順 4、 2の画像 2
      • Using the plastic prying tool, carefully pry up one corner of the badge, and slip the floss underneath.
      • You don't want to use too much force on the prying tool, as this can result in denting.
      • Draw the floss back and forth in a sawing motion and simultaneously pull it along the perimeter of the badge until it detaches from the panel.
      • Do not use metal fishing line or metal wires, as these will damage your paint.
      FixBotに聞いてみる
      コメントを追加
    5. Debadging a Ferrari, Clean off the leftover adhesive: 手順 5、 1の画像 1
      • With the badge removed you can now use soapy water and the abrasive side of a sponge to remove the excess adhesive. Other products such as Goo Gone or Goof Off are also excellent adhesive removers.
      • Take care not to scrub not too hard, as this can ruin your paint.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reattach your badge, apply new adhesive and follow these instructions in reverse order.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Jacob Mehnert
メンバー登録日: 10/18/21
49,554 ポイント
52のガイドは作成済み
チーム
iFanatics iFanatics人のメンバー
Community
69 メンバー
519のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 49
今までの合計 1,529
