メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Debadging a Car
必要な工具と部品
  1. Debadging a Car, Debadging a Car: 手順 1、 3の画像 1 Debadging a Car, Debadging a Car: 手順 1、 3の画像 2 Debadging a Car, Debadging a Car: 手順 1、 3の画像 3
    • Begin by thoroughly wetting the badge and surrounding area with soapy water.
    • Once the badge is fully wetted, wedge a strand of floss or fishing line between the car panel and the wedge.
    • Do not use metal fishing line or metal wires, as these will damage the paint.
    • Draw the floss back and forth in a sawing motion and simultaneously pull it along the badge until it detaches from the panel.
    FixBotに聞いてみる
    コメントを追加
  2. Debadging a Car: 手順 2、 2の画像 1 Debadging a Car: 手順 2、 2の画像 2
    • Use soapy water and the rough side of a sponge to remove the leftover adhesive. Other products such as Goo Gone or Goof Off are also excellent adhesive removers.
    • Be sure to monitor your scrubbing carefully. If you scrub too hard in one area, you will damage the paint.
    FixBotに聞いてみる
    コメントを追加
終わりに
There you have it. A fresh clean tailgate without any badge.
キャンセル: このガイドを終了できませんでした。
22 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Miroslav Djuric
160,981 ポイント
144のガイドは作成済み
8件のガイドコメント
Dental floss. Good idea.
Thurman - 返信 共有
This thanks for this post, many of people have craze to use custom badge. This is good think you can get choice to use any of custom badge to stick on car with the Instant Adhesives.
Bryan - 返信 共有
Floss is a good idea. I would suggest using a hair dryer to first heat the area to soften the adhesive. When done you can use duct tape to "lift" small patches of remaining adhesive by pressing duct tape firmly over small sections of adhesive and then lifting straight up.
Mike - 返信 共有
I find ifixit's conclusion to be rather comical; To reassemble your device, follow these instructions in reverse order.
grumblerts - 返信 共有
Rather than using an abrasive washing up sponge, try using a soft cloth with WD40. It will dissolve the remove the adhesive without risking damaging the paintwork.
Gordon Grace - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 33
過去 30 日: 194
今までの合計 23,994
