必要な工具と部品
Use Phillips #00 Screwdriver to remove the three screws that hold the upper portion of the access panel.
Remove the blade cutter assembly.
Use Phillips #00 Screwdriver to remove the last two screws located in the battery panel that holds the bottom portion of the access panel.
Use Phillips #00 Screwdriver to remove three screws that hold down the circuit board.
Gently lift the bottom of the circuit board, revealing the keypad.
