メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DJI Phantom 2 Vision+ Propellers Removal
必要な工具と部品
    1. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: 手順 1、 3の画像 1 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: 手順 1、 3の画像 2 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: 手順 1、 3の画像 3
      • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
      • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
      FixBotに聞いてみる
      コメントを追加
    1. DJI Phantom 2 Vision+ Propellers Removal, Propellers: 手順 2、 1の画像 1
      • Determine if the propellor is clockwise or counter-clockwise rotating.
      • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
      • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
      • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
      FixBotに聞いてみる
      コメントを追加
    2. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: 手順 3、 3の画像 1 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: 手順 3、 3の画像 2 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: 手順 3、 3の画像 3
      • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
      • Remove the propellor.
      FixBotに聞いてみる
      コメントを追加
    3. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: 手順 4、 3の画像 1 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: 手順 4、 3の画像 2 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: 手順 4、 3の画像 3
      • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
David Hoyt
メンバー登録日: 04/09/10
4,053 ポイント
39のガイドは作成済み
チーム
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G89
4 メンバー
344のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 36
今までの合計 7,607
