はじめに
The heat sink is responsible for regulating the heat flow and temperature control in your device. If your device is overheating and not cooling itself down properly, then the heat sink will need to be replaced. Follow this guide for the steps on how to replace the heat sink.
必要な工具と部品
Unscrew the two 7mm screws with a Phillips #1 screwdriver.
Lift the heat sink off the metal plate with your fingers.
ある他の人がこのガイドを完成しました。
