メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Cricut Maker Motherboard Replacement
必要な工具と部品
    1. Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: 手順 1、 3の画像 1 Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: 手順 1、 3の画像 2 Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: 手順 1、 3の画像 3
      • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
      • Applying too much pressure to this can break it as it is very fragile.
      • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
      • Remove the cover from the connecting joint and set it aside.
      FixBotに聞いてみる
      コメントを追加
    2. Cricut Maker Motherboard Replacement: 手順 2、 2の画像 1 Cricut Maker Motherboard Replacement: 手順 2、 2の画像 2
      • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
      FixBotに聞いてみる
      コメントを追加
    3. Cricut Maker Motherboard Replacement: 手順 3、 3の画像 1 Cricut Maker Motherboard Replacement: 手順 3、 3の画像 2 Cricut Maker Motherboard Replacement: 手順 3、 3の画像 3
      • Turn the device around, so that the back is facing you.
      • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
      • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
      • These actions should reveal the cylindrical connectors.
      FixBotに聞いてみる
      コメントを追加
    4. Cricut Maker Motherboard Replacement: 手順 4、 1の画像 1
      • Press down on the lid.
      • Push the lid outwards to free it from the jointed clasps.
      FixBotに聞いてみる
      コメントを追加
    1. Cricut Maker Motherboard Replacement, Front Door Replacement: 手順 5、 2の画像 1 Cricut Maker Motherboard Replacement, Front Door Replacement: 手順 5、 2の画像 2
      • Using your hands or an opening tool, remove the four foot pads covering four screws.
      • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
      FixBotに聞いてみる
      コメントを追加
    2. Cricut Maker Motherboard Replacement: 手順 6、 3の画像 1 Cricut Maker Motherboard Replacement: 手順 6、 3の画像 2 Cricut Maker Motherboard Replacement: 手順 6、 3の画像 3
      • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
      • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
      • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
      FixBotに聞いてみる
      コメントを追加
    3. Cricut Maker Motherboard Replacement: 手順 7、 3の画像 1 Cricut Maker Motherboard Replacement: 手順 7、 3の画像 2 Cricut Maker Motherboard Replacement: 手順 7、 3の画像 3
      • Turn the device on its side.
      • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
      FixBotに聞いてみる
      コメントを追加
    4. Cricut Maker Motherboard Replacement: 手順 8、 3の画像 1 Cricut Maker Motherboard Replacement: 手順 8、 3の画像 2 Cricut Maker Motherboard Replacement: 手順 8、 3の画像 3
      • Lift the top case off of the base of the device.
      • After removing this cover, the internals of the device will be exposed.
      FixBotに聞いてみる
      コメントを追加
    5. Cricut Maker Motherboard Replacement: 手順 9、 2の画像 1 Cricut Maker Motherboard Replacement: 手順 9、 2の画像 2
      • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
      • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
      FixBotに聞いてみる
      コメントを追加
    6. Cricut Maker Motherboard Replacement: 手順 10、 3の画像 1 Cricut Maker Motherboard Replacement: 手順 10、 3の画像 2 Cricut Maker Motherboard Replacement: 手順 10、 3の画像 3
      • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
      • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
      FixBotに聞いてみる
      コメントを追加
    7. Cricut Maker Motherboard Replacement: 手順 11、 2の画像 1 Cricut Maker Motherboard Replacement: 手順 11、 2の画像 2
      • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
      FixBotに聞いてみる
      コメントを追加
    8. Cricut Maker Motherboard Replacement: 手順 12、 2の画像 1 Cricut Maker Motherboard Replacement: 手順 12、 2の画像 2
      • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
      • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
      FixBotに聞いてみる
      コメントを追加
    9. Cricut Maker Motherboard Replacement: 手順 13、 3の画像 1 Cricut Maker Motherboard Replacement: 手順 13、 3の画像 2 Cricut Maker Motherboard Replacement: 手順 13、 3の画像 3
      • Remove a total of seven 10 mm screws from the underside of the door.
      • One side of the base has two 10mm screws.
      • The other side of the base has five 10 mm screws.
      FixBotに聞いてみる
      コメントを追加
    10. Cricut Maker Motherboard Replacement: 手順 14、 3の画像 1 Cricut Maker Motherboard Replacement: 手順 14、 3の画像 2 Cricut Maker Motherboard Replacement: 手順 14、 3の画像 3
      • Pry the door from hinges using an iFixit opening tool.
      • Lift upwards and towards you, to remove the door from the hinges.
      FixBotに聞いてみる
      コメントを追加
    1. Cricut Maker Motherboard Replacement, Motherboard Replacement: 手順 15、 3の画像 1 Cricut Maker Motherboard Replacement, Motherboard Replacement: 手順 15、 3の画像 2 Cricut Maker Motherboard Replacement, Motherboard Replacement: 手順 15、 3の画像 3
      • Use a Phillips #2 screwdriver to remove the five 7 mm screws from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. Cricut Maker Motherboard Replacement: 手順 16、 1の画像 1
      • Remove the gray electrical tape from the cables.
      FixBotに聞いてみる
      コメントを追加
    3. Cricut Maker Motherboard Replacement: 手順 17、 2の画像 1 Cricut Maker Motherboard Replacement: 手順 17、 2の画像 2
      • Unplug both cables from the corners of the motherboard by pulling them upwards from the base of the connectors.
      FixBotに聞いてみる
      コメントを追加
    4. Cricut Maker Motherboard Replacement: 手順 18、 2の画像 1 Cricut Maker Motherboard Replacement: 手順 18、 2の画像 2
      • Gently slide the motherboard out from USB port slot to remove it from the device.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Devyn White
メンバー登録日: 09/20/22
1,161 ポイント
5のガイドは作成済み
チーム
Austin Community College, Team 9-1, Watkins Fall 2022 Austin Community College, Team 9-1, Watkins Fall 2022人のメンバー
AUSTINCC-WATKINS-F22S9G1
3 メンバー
27のガイドは作成済み
11件のガイドコメント
So do you sell the motherboard or know where it buy one for cricut cxpl301
David Washington - 返信 共有
I too am looking for a replacement board. It was suggested to me that I could contact one of the pcb repair companies. For a fee, they will either check and repair your board or they will copy and print a new board and mail it back to you. You have to send in your board for them to check and copy though. So I guess reputation and reviews would be priority. It would suck to send our boards off and never receive a new one or the old one. :-/.
Jennifer Daniels - 返信 共有
Cricut does not sell parts. Cricut does not do repairs.
B·Ware - 返信 共有
sooooo, theres no place to get parts? thats stupid...might as well just through it away then...
Kirk Serbian - 返信 共有
Bonjour pourriez vous nous dire où trouver la carte mère svp
Magali Magnier - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 39
過去 30 日: 229
今までの合計 12,298
