必要な工具と部品
Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
The right speaker is directly below the battery as shown.
Remove the two 4mm Phillips #00 screws found in the speaker at the bottom left corner of the device.
ある他の人がこのガイドを完成しました。
