メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Creative Zen Vision M Screen Replacement
必要な工具と部品
    1. Creative Zen Vision M Screen Replacement, Opening the top: 手順 1、 2の画像 1 Creative Zen Vision M Screen Replacement, Opening the top: 手順 1、 2の画像 2
      • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
      • Unscrew and remove the two exposed Phillips head screws.
      FixBotに聞いてみる
      コメントを追加
    2. Creative Zen Vision M Screen Replacement, Opening the device: 手順 2、 2の画像 1 Creative Zen Vision M Screen Replacement, Opening the device: 手順 2、 2の画像 2
      • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
      • Don't try attempt to open it from the recess between the buttons and the device.
      FixBotに聞いてみる
      コメントを追加
    3. Creative Zen Vision M Screen Replacement, Disconnecting the battery: 手順 3、 3の画像 1 Creative Zen Vision M Screen Replacement, Disconnecting the battery: 手順 3、 3の画像 2 Creative Zen Vision M Screen Replacement, Disconnecting the battery: 手順 3、 3の画像 3
      • Disconnect the wire from the bottom device.
      • Handle with care as the wires tend to disconnect easily.
      FixBotに聞いてみる
      コメントを追加
    4. Creative Zen Vision M Screen Replacement, Disconnecting the hard drive: 手順 4、 1の画像 1
      • In the top right corner, pull the black foam square off to separate the hard drive from the screen.
      • Handle with care as the hard drive also comes off easily.
      FixBotに聞いてみる
      コメントを追加
    5. Creative Zen Vision M Screen Replacement, Unscrewing from the mother board: 手順 5、 1の画像 1
      • Unscrew the seven screws placed around the mother board.
      • You will need a one millimeter Phillips head screwdriver.
      • The screws are small, so keep them safely.
      FixBotに聞いてみる
      コメントを追加
    6. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 手順 6、 3の画像 1 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 手順 6、 3の画像 2 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 手順 6、 3の画像 3
      • Flip your device upside down so that the motherboard will loosen.
      • Detach the connector from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    7. Creative Zen Vision M Screen Replacement, Removing the screen: 手順 7、 2の画像 1 Creative Zen Vision M Screen Replacement, Removing the screen: 手順 7、 2の画像 2
      • Tilt the screen diagonally. Separate the screen and motherboard from the device frame.
      • Lift the light gray flap to detach the screen from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    8. Creative Zen Vision M Screen Replacement, Seperating the digital display: 手順 8、 2の画像 1 Creative Zen Vision M Screen Replacement, Seperating the digital display: 手順 8、 2の画像 2
      • Separate the clear screen frame from the digital display.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Kirstie G
メンバー登録日: 10/12/16
488 ポイント
4のガイドは作成済み
チーム
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016人のメンバー
TTU-BENNETT-F16S12G1
4 メンバー
13のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 43
今までの合計 1,997
