メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Creative Zen Vision M Hard-drive Replacement
必要な工具と部品
    1. Creative Zen Vision M Hard-drive Replacement, Opening the top: 手順 1、 2の画像 1 Creative Zen Vision M Hard-drive Replacement, Opening the top: 手順 1、 2の画像 2
      • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
      • Unscrew and remove the two exposed Phillips head screws.
      • Do the same for the bottom plastic surrounding the bottom connector, as there are two screws under here as well.
      FixBotに聞いてみる
      コメントを追加
    2. Creative Zen Vision M Hard-drive Replacement, Opening the device: 手順 2、 2の画像 1 Creative Zen Vision M Hard-drive Replacement, Opening the device: 手順 2、 2の画像 2
      • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
      • Don't try attempt to open it from the recess between the buttons and the device.
      FixBotに聞いてみる
      コメントを追加
    3. Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: 手順 3、 3の画像 1 Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: 手順 3、 3の画像 2 Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: 手順 3、 3の画像 3
      • To detach wires from the screen, gently tug on the wires connected to the battery. They are located on the bottom half of the screen.
      FixBotに聞いてみる
      コメントを追加
    4. Creative Zen Vision M Hard-drive Replacement, Disconnecting the hard drive: 手順 4、 1の画像 1
      • Pull black hard drive connector located at the top right.
      • Ensure, as demonstrated by the image, that the screen is safely removed first. There is an iFixit guide showing how to carefully pull apart the Creative Zen Vision M.
      FixBotに聞いてみる
      コメントを追加
    5. Creative Zen Vision M Hard-drive Replacement, Removing bumpers: 手順 5、 1の画像 1
      • Pull off blue bumpers and connect to new hard drive
      FixBotに聞いてみる
      コメントを追加
    6. Creative Zen Vision M Hard-drive Replacement, Removing hard drive connector: 手順 6、 2の画像 1 Creative Zen Vision M Hard-drive Replacement, Removing hard drive connector: 手順 6、 2の画像 2
      • Lift white flap on top of hard drive to disconnect hard drive connector.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Kirstie G
メンバー登録日: 10/12/16
488 ポイント
4のガイドは作成済み
チーム
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016人のメンバー
TTU-BENNETT-F16S12G1
4 メンバー
13のガイドは作成済み
3件のガイドコメント
How do you get the firmware on the new hard drive?
Selvedge - 返信 共有
Download the firmware software from: http://support.creative.com/Downloads/we...
(Select firmware).
Then:
Close all application windows that are currently running on your computer.
Connect your player to your computer.
Double-click the downloaded file and follow the instructions on the screen.
Regards.
Brendan Eager - 返信 共有
I should also update the link provided. Here’s a slightly better link. Select “Zen Series” then your specific model. To flash the firmware on the new hard drive. Download the file into your local hard disk. Close all application windows that are currently running on your computer. Connect your player to your computer (with the included adapter and USB wire). Double-click the downloaded file and follow the instructions on the screen.
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 67
今までの合計 5,337
