メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Creating a Bootable SD Card
必要な工具と部品
    1. Creating a Bootable SD Card, Downloading Raspberry Pi Imager: 手順 1、 3の画像 1 Creating a Bootable SD Card, Downloading Raspberry Pi Imager: 手順 1、 3の画像 2 Creating a Bootable SD Card, Downloading Raspberry Pi Imager: 手順 1、 3の画像 3
      • To create our Bootable SD Card we will need the Official Raspberry Pi Imager software. This software is completely free, and can be downloaded here.
      FixBotに聞いてみる
      コメントを追加
    2. Creating a Bootable SD Card, Configuring your SD Card: 手順 2、 1の画像 1
      • Once your download has been completed, open the Pi Imager program, and insert your SD Card into your computer. The Imager software should automatically detect your SD Card, and will begin to format the card.
      • Formatting your SD Card will erase any content that has been saved onto the card. Be sure to backup any photos or files to your machine before formatting.
      FixBotに聞いてみる
      コメントを追加
    3. Creating a Bootable SD Card, Select your Operating System: 手順 3、 2の画像 1 Creating a Bootable SD Card, Select your Operating System: 手順 3、 2の画像 2
      • Once your SD Card has been targeted, you'll need to select the Operating System that you would like loaded onto your SD Card.
      • Imager comes pre-loaded with several operating systems, however you can select a custom OS by scrolling to the bottom of the list of OS'.
      FixBotに聞いてみる
      コメントを追加
    4. Creating a Bootable SD Card, Choosing your SD Card: 手順 4、 2の画像 1 Creating a Bootable SD Card, Choosing your SD Card: 手順 4、 2の画像 2
      • Once your OS has been selected, select your inserted SD card.
      FixBotに聞いてみる
      コメントを追加
    5. Creating a Bootable SD Card, Writing the OS to your SD Card: 手順 5、 2の画像 1 Creating a Bootable SD Card, Writing the OS to your SD Card: 手順 5、 2の画像 2
      • Once you have your SD Card selected, click on the Write button. If prompted enter the password to your computer.
      • This step will erase any data that is on the SD Card. Be sure to back up any files or photos you wish to save to your computer
      FixBotに聞いてみる
      コメントを追加
      • When the installation is complete, Imager will prompt you to remove your SD Card.
      • Imager will automatically eject your SD Card, so it should be safe for you to remove it once the installation is complete.
      • To begin using your Bootable SD Card, simply insert the card into your Raspberry Pi, and power on your device.
      FixBotに聞いてみる
      コメントを追加
      • It is possible that at the moment you begin to WRITE the OS to your SD Card an alert may appear warning that the card is write protected. This happens when the switch on the left side of the SD is in protection mode.
      • You can solve this by ejecting the SD Card and move the lever to the side opposite, then repeat the OS selection operation. and of the SD Card.
      FixBotに聞いてみる
      コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
it en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Ema.exe
メンバー登録日: 06/19/22
538 ポイント
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 77
今までの合計 2,074
