メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Creating Apple Lisa KeyCaps
必要な工具と部品
    1. Creating Apple Lisa KeyCaps, Selecting Keys: 手順 1、 2の画像 1 Creating Apple Lisa KeyCaps, Selecting Keys: 手順 1、 2の画像 2
      • My keyboard was missing a variety of keys so I needed to select source keys to create the molds. On the 2nd image all the like-keys are color-coded.
      FixBotに聞いてみる
      コメントを追加
    2. Creating Apple Lisa KeyCaps, Base Mold: 手順 2、 1の画像 1
      • Mix enough putty that the source key will fit in. Make sure the edge of the key is flush with the top of the putty to ensure the key is the correct size.
      FixBotに聞いてみる
      コメントを追加
    3. Creating Apple Lisa KeyCaps, Connector Mold: 手順 3、 1の画像 1
      • Once the base mold is set, mix a tiny amount of putty to press down into the key. Unseen in this photo: press the putty down right to the pegs of the source key so they are poking holes in the top of the mold.
      FixBotに聞いてみる
      コメントを追加
      • Put on a pair of disposable rubber gloves or you’ll be peeling off the resin from your fingers for weeks.
      FixBotに聞いてみる
      コメントを追加
    4. Creating Apple Lisa KeyCaps, Casting: 手順 5、 1の画像 1
      • Mix a tiny amount of resin as directed on the bottle. Ensure you are measuring accurately. Pour the resin into the base mold until 3/4th filled. Put the top mold on top of the base mold as to cast the connector onto the mold. Unseen in this photo is the correct top mold with the exposed holes on top. Pour liquid resin into the top to fill the holes
      FixBotに聞いてみる
      コメントを追加
    5. Creating Apple Lisa KeyCaps, Setting Up: 手順 6、 1の画像 1
      • After about half an hour remove the key from the mold and set aside to finish setting up. Be careful not to snap the connectors off when removing from mold. Sand off the edges if needed.
      FixBotに聞いてみる
      コメントを追加
    6. Creating Apple Lisa KeyCaps, Painting: 手順 7、 1の画像 1
      • Once the key(s) have set up, you can now paint. Be careful not to overpaint which will lead to the key being too thick.
      FixBotに聞いてみる
      コメントを追加
    7. Creating Apple Lisa KeyCaps, Fitting: 手順 8、 1の画像 1
      • Assemble the keys to ensure they work before writing the key symbols. If you need replacement springs, I suggest the spring kit (listed in the parts section.) it has 8 useable springs per kit for this kind of project.
      FixBotに聞いてみる
      コメントを追加
    8. Creating Apple Lisa KeyCaps, Key Symbols: 手順 9、 1の画像 1
      • Once you are happy with the keys, use a fine tip sharpie to write the key symbols. Let the sharpie dry for a day.
      FixBotに聞いてみる
      コメントを追加
終わりに
While crude, they work quite well especially after you spend a huge amount of time online realizing there are no places to buy replacement keycaps.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
LisaGuide
メンバー登録日: 12/30/18
1,833 ポイント
11のガイドは作成済み
1件のガイドコメント
No, the results are unfortunately not convincing (sorry to say that). Maybe it is better using a 3D printer for this ...?
Peter Mueller - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 29
今までの合計 965
