はじめに
This guide will give you step-by-step instructions on how to replace the record slider on your Contour Roam2 waterproof action camera if the camera won't begin or end recording properly.
必要な工具と部品
Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
3 の人々がこのガイドを完成させました。
2件のガイドコメント
I have had this camera since I was 16 I am 21 now and there was something wrong with the slider I am glad I didn't get rid of it! Because of you it is fixed now!!!
Dose anyone know if there is an equivalent guide but for the “Contour +2”?
