メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Connect Four Electronic Handheld Screen Replacement
必要な工具と部品
    1. Connect Four Electronic Handheld Screen Replacement, Ensure the device is off.: 手順 1、 1の画像 1
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      FixBotに聞いてみる
      コメントを追加
    2. Connect Four Electronic Handheld Screen Replacement, Removing the battery casing.: 手順 2、 2の画像 1 Connect Four Electronic Handheld Screen Replacement, Removing the battery casing.: 手順 2、 2の画像 2
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      FixBotに聞いてみる
      コメントを追加
    1. Connect Four Electronic Handheld Screen Replacement, Removing/Replacing the Back Casing: 手順 3、 2の画像 1 Connect Four Electronic Handheld Screen Replacement, Removing/Replacing the Back Casing: 手順 3、 2の画像 2
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      FixBotに聞いてみる
      コメントを追加
    1. Connect Four Electronic Handheld Screen Replacement, Detaching the circuit board.: 手順 4、 3の画像 1 Connect Four Electronic Handheld Screen Replacement, Detaching the circuit board.: 手順 4、 3の画像 2 Connect Four Electronic Handheld Screen Replacement, Detaching the circuit board.: 手順 4、 3の画像 3
      • Using a Phillips head screwdriver, remove the six (0.25"-length) #3 screws that hold down the cpu board.
      • Using a plastic opening tool, lever the circuit board just enough to where you can easily access the button sheet.
      FixBotに聞いてみる
      コメントを追加
    2. Connect Four Electronic Handheld Screen Replacement, Removing the Circuit Board: 手順 5、 2の画像 1 Connect Four Electronic Handheld Screen Replacement, Removing the Circuit Board: 手順 5、 2の画像 2
      この手順で使用する道具:
      • Pop out the wires, connected to the battery terminals, out of their place. You can use a plastic opening tool or fine tweezers for this step.
      • The wires in this image have already been detached.
      • Check that there is no power going into the device that could pose any shock hazard.
      • Once the terminals are out of place, remove the circuit board.
      FixBotに聞いてみる
      コメントを追加
    3. Connect Four Electronic Handheld Screen Replacement, Replacing the Screen: 手順 6、 1の画像 1
      • Take the old screen out.
      • Replace the old screen with the new screen.
      • Ensure that the screen is facing right side up, where there is more yellow space under the checkered board.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Wil
メンバー登録日: 10/22/14
313 ポイント
3のガイドは作成済み
チーム
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G11
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 793
