メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ClickN Kids Tablet Camera Replacement
必要な工具と部品
    1. ClickN Kids Tablet Camera Replacement, Camera: 手順 1、 1の画像 1
      • Start on the side with the camera
      • Insert a plastic opening tool into the space between the screen and the back side.
      • The screen side is black, the back side is colored
      FixBotに聞いてみる
      コメントを追加
    2. ClickN Kids Tablet Camera Replacement: 手順 2、 1の画像 1
      • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
      • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
      • The corners can be tricky. Make sure to separate the pieces all the way around the tablet before attempting to open it.
      FixBotに聞いてみる
      コメントを追加
    3. ClickN Kids Tablet Camera Replacement: 手順 3、 1の画像 1
      • Lift the detached screen from the camera side until you can see the inside of the tablet.
      • Don't open too fast, or you might damage the ribbons cables.
      FixBotに聞いてみる
      コメントを追加
    4. ClickN Kids Tablet Camera Replacement: 手順 4、 2の画像 1 ClickN Kids Tablet Camera Replacement: 手順 4、 2の画像 2
      • Be careful not to damage any wires or ribbon cables during this step.
      • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
      • There is a black tab behind the long ribbon cable. Lift up the black tab.
      • For the ribbon cable in the back, pull the black tabs on the side out.
      • Detach the ribbon cables connecting the screen to the motherboard.
      • Remove any tape that is holding down the ribbon cables. Set it aside.
      FixBotに聞いてみる
      コメントを追加
    5. ClickN Kids Tablet Camera Replacement: 手順 5、 1の画像 1
      • Pull off the tape that holds the ribbon cable to the battery.
      FixBotに聞いてみる
      コメントを追加
    6. ClickN Kids Tablet Camera Replacement: 手順 6、 2の画像 1 ClickN Kids Tablet Camera Replacement: 手順 6、 2の画像 2
      • Be careful not to damage the wires or ribbon cables.
      • Pull out the two black ends of the base on the motherboard.
      • Slide out the camera’s ribbon cable once the ends are loosened.
      FixBotに聞いてみる
      コメントを追加
    7. ClickN Kids Tablet Camera Replacement: 手順 7、 3の画像 1 ClickN Kids Tablet Camera Replacement: 手順 7、 3の画像 2 ClickN Kids Tablet Camera Replacement: 手順 7、 3の画像 3
      • Use a plastic opening tool to pry the camera out of its place.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kevin Finney
メンバー登録日: 03/22/15
562 ポイント
4のガイドは作成済み
チーム
Baylor, Team 4-4, Williams Spring 2015 Baylor, Team 4-4, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S4G4
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 37
今までの合計 1,160
