はじめに
If the dial is stuck in any particular position it will be necessary to replace. This guide will show how to locate and replace the dial.
必要な工具と部品
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
Remove the battery from the meter before continuing.
Carefully remove dial from device by lifting upward.
Clean existing dial or replace if necessary.
ある他の人がこのガイドを完成しました。
