メインコンテンツにスキップ
Casio G-Shock GA110-1B Battery Replacement
必要な工具と部品
ビデオの概要
  1. Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: 手順 1、 3の画像 1 Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: 手順 1、 3の画像 2 Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: 手順 1、 3の画像 3
    • Remove the four screws from the back of the watch using the Phillips #0 Screwdriver
  2. Casio G-Shock GA110-1B Battery Replacement: 手順 2、 3の画像 1 Casio G-Shock GA110-1B Battery Replacement: 手順 2、 3の画像 2 Casio G-Shock GA110-1B Battery Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to remove the metal cover.
    • Make sure not to lose the rubber circle underneath the metal cover because it's part of the watch.
  3. Casio G-Shock GA110-1B Battery Replacement: 手順 3、 1の画像 1
    • Remove the white cover carefully.
    • Using the pair of tweezers, unhook where the battery is held onto.
    • You are going to need to pull the hook will a bit of force. As seen in the video.
    • Be careful!! Do not pull it too hard with the tweezers. You don't want to damage the hook where the battery is placed.
  4. Casio G-Shock GA110-1B Battery Replacement: 手順 5、 3の画像 1 Casio G-Shock GA110-1B Battery Replacement: 手順 5、 3の画像 2 Casio G-Shock GA110-1B Battery Replacement: 手順 5、 3の画像 3
    • Use a pair of tweezers or your fingers to remove the battery from its place.
    • Remove the new battery from its packaging.
  5. Casio G-Shock GA110-1B Battery Replacement: 手順 6、 2の画像 1 Casio G-Shock GA110-1B Battery Replacement: 手順 6、 2の画像 2
    • Place the new battery where it belongs with your fingers. Hook it back onto the device to secure it in place.
    • Reattach the white cover onto the device.
  6. Casio G-Shock GA110-1B Battery Replacement: 手順 7、 3の画像 1 Casio G-Shock GA110-1B Battery Replacement: 手順 7、 3の画像 2 Casio G-Shock GA110-1B Battery Replacement: 手順 7、 3の画像 3
    • Don't forget that the rubber goes 1st inside the watch before placing the metal cover.
    • Make sure that the metal cover is aligned with the watch and not upside down.
    • Put back the metal cover and screw in back the four screws using the Phillips #0 screwdriver.
    • After screwing in the four screws, flip the watch over. Push the button on the bottom left and the watch should turn on!
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Hector Mejia
メンバー登録日: 10/05/21
361 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 11-3, Grodsky Fall 2021 CSU Los Angeles, Team 11-3, Grodsky Fall 2021人のメンバー
CSULA-GRODSKY-F21S11G3
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 78
過去 30 日: 332
今までの合計 4,543
