メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Casio CTK-3200 LCD Screen Replacement
必要な工具と部品
  1. Casio CTK-3200 LCD Screen Replacement, Center Front Panel: 手順 1、 2の画像 1 Casio CTK-3200 LCD Screen Replacement, Center Front Panel: 手順 1、 2の画像 2
    • Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
    FixBotに聞いてみる
    コメントを追加
  2. Casio CTK-3200 LCD Screen Replacement: 手順 2、 1の画像 1
    • Flip the keyboard over and remove the central panel on the front and place it above the keyboard.
    • Make sure not to sever or strain any connections between the yellow-colored main board and the central panel.
    • If the panel is not easily removable, make sure all the screws are removed from the back.
    FixBotに聞いてみる
    コメントを追加
  3. Casio CTK-3200 LCD Screen Replacement, Main Board: 手順 3、 1の画像 1
    • Make sure you are not putting too much strain on the wires that connect the yellow board to the rest of the piano.
    FixBotに聞いてみる
    コメントを追加
  4. Casio CTK-3200 LCD Screen Replacement: 手順 4、 2の画像 1 Casio CTK-3200 LCD Screen Replacement: 手順 4、 2の画像 2
    • Remove the three 12 mm Phillips #2 screws from the green PCB.
    • This step will require you to move some of the motherboard's wiring. Make sure not to separate any of the connection points.
    FixBotに聞いてみる
    コメントを追加
  5. Casio CTK-3200 LCD Screen Replacement: 手順 5、 2の画像 1 Casio CTK-3200 LCD Screen Replacement: 手順 5、 2の画像 2
    • Remove all twenty-three of the 10 mm Phillips #1 screws from the yellow circuit board.
    FixBotに聞いてみる
    コメントを追加
  6. Casio CTK-3200 LCD Screen Replacement: 手順 6、 1の画像 1
    • The board is now able to be removed from the center front panel. Carefully remove the board, making certain not to break the board or any of the components attached to it.
    • Make sure the center front panel is facing down for this step, as the keys will come loose from the front of the panel.
    FixBotに聞いてみる
    コメントを追加
  7. Casio CTK-3200 LCD Screen Replacement, LCD Screen: 手順 7、 2の画像 1 Casio CTK-3200 LCD Screen Replacement, LCD Screen: 手順 7、 2の画像 2
    • Carefully lift out the LCD screen.
    • If the screen has not been taken off before it might seem like it is glued to the board; this is normal.
    FixBotに聞いてみる
    コメントを追加
  8. Casio CTK-3200 LCD Screen Replacement: 手順 8、 2の画像 1 Casio CTK-3200 LCD Screen Replacement: 手順 8、 2の画像 2
    • Place your new screen face down into the center panel. Lay the screen exactly as shown in the first image, then let it fall over and land face down into place.
    • Make sure the screen is right side up. This will ensure that all of the electrical components line up correctly when the main board is re-attached to the center panel.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Will Wright
メンバー登録日: 10/23/24
369 ポイント
2のガイドは作成済み
チーム
Cuesta, Team 10-4, Krynen Fall 2024 Cuesta, Team 10-4, Krynen Fall 2024人のメンバー
CUESTA-KRYNEN-F24S10G4
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 25
今までの合計 548
