メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Capresso Perfectea 260 Handle Replacement
必要な工具と部品
    1. Capresso Perfectea 260 Handle Replacement, Lid: 手順 1、 1の画像 1
      • Lift the lid of the Perfectea
      • Remove the two 12mm Phillips #2 screws located at the brim of the pot.
      FixBotに聞いてみる
      コメントを追加
    2. Capresso Perfectea 260 Handle Replacement: 手順 2、 3の画像 1 Capresso Perfectea 260 Handle Replacement: 手順 2、 3の画像 2 Capresso Perfectea 260 Handle Replacement: 手順 2、 3の画像 3
      • Adhesive tape is left holding the lid to the glass pot.
      • Use the spudger for this step.
      • With one hand, firmly grip the lid while designating your other hand to wedge the spudger between the lid and the glass pot.
      • Working from the outside to the inside, gently pry the adhesive tape from the glass pot, detaching the lid.
      FixBotに聞いてみる
      コメントを追加
    1. Capresso Perfectea 260 Handle Replacement, Handle: 手順 3、 3の画像 1 Capresso Perfectea 260 Handle Replacement, Handle: 手順 3、 3の画像 2 Capresso Perfectea 260 Handle Replacement, Handle: 手順 3、 3の画像 3
      • Use the plastic opening tool for this step.
      • Firmly grip the glass pot with one hand while using the other to slip the flat end of the plastic opening tool between the glass pot and the adhesive tape holding the handle to the glass pot.
      • Gently pry the adhesive tape from the glass pot. Work your way around the handle until the handle is loose and not attached to the pot anymore.
      FixBotに聞いてみる
      コメントを追加
    2. Capresso Perfectea 260 Handle Replacement: 手順 4、 1の画像 1
      • Once the handle is loose, locate the four 10 mm Phillips #2 screws from the base of the Perfectea and remove them.
      • Remove the base.
      FixBotに聞いてみる
      コメントを追加
    3. Capresso Perfectea 260 Handle Replacement: 手順 5、 1の画像 1
      • Locate the two 10 mm Phillips #2 screws at the bottom of the handle and remove them.
      FixBotに聞いてみる
      コメントを追加
    4. Capresso Perfectea 260 Handle Replacement: 手順 6、 2の画像 1 Capresso Perfectea 260 Handle Replacement: 手順 6、 2の画像 2
      • In order to free the bottom of the handle, remove the plastic piece that was held by the two screws
      • While firmly holding the glass pot, gently slide the bottom of the handle up and out of the base of the pot.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Kenji Anzai
メンバー登録日: 04/14/15
594 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-17, Maness Spring 2015 Cal Poly, Team 6-17, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S6G17
4 メンバー
12のガイドは作成済み
1件のガイドコメント
This guide applies to the Capresso H2O kettle too. Thanks for the guide.
Giovanni Ciriani - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 35
今までの合計 993
