はじめに
By fixing your flash, you can once again take bright, vibrant photographs.
必要な工具と部品
To remove the battery, locate the battery cover on the bottom of the camera.
Using your thumb, press down on the cover and slide it outwards.
Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
Fix your Canon's flash in order to take bright, vibrant photographs.
2 の人々がこのガイドを完成させました。
1件のガイドコメント
my SX610 HS flash didn't work. im trying to just troubleshoot it to see if it might came loose or anything. do i still need to do all steps?
