はじめに
This guide will walk you through a lens assembly replacement procedure.
必要な工具と部品
Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
Remove the LCD cable by gently prying the hinge open with a spudger or your finger. The cable should easily slide out.
5 の人々がこのガイドを完成させました。
