メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot SD450 LCD Screen Replacement
必要な工具と部品
    1. Canon PowerShot SD450 LCD Screen Replacement, Casing: 手順 1、 1の画像 1
      • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
      • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
      FixBotに聞いてみる
      コメントを追加
    2. Canon PowerShot SD450 LCD Screen Replacement: 手順 2、 1の画像 1
      • Pull the lanyard mount off of the camera using a spudger or your fingers.
      FixBotに聞いてみる
      コメントを追加
    3. Canon PowerShot SD450 LCD Screen Replacement: 手順 3、 2の画像 1 Canon PowerShot SD450 LCD Screen Replacement: 手順 3、 2の画像 2
      • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
      • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
      FixBotに聞いてみる
      コメントを追加
    4. Canon PowerShot SD450 LCD Screen Replacement: 手順 4、 1の画像 1
      • Take hold of the inside of the camera, and gently pull away from the back casing.
      FixBotに聞いてみる
      コメントを追加
    5. Canon PowerShot SD450 LCD Screen Replacement: 手順 5、 1の画像 1
      • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
      FixBotに聞いてみる
      コメントを追加
    6. Canon PowerShot SD450 LCD Screen Replacement: 手順 6、 1の画像 1
      • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
      • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
      FixBotに聞いてみる
      コメントを追加
    1. Canon PowerShot SD450 LCD Screen Replacement, LCD Screen: 手順 7、 2の画像 1 Canon PowerShot SD450 LCD Screen Replacement, LCD Screen: 手順 7、 2の画像 2
      • Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket.
      FixBotに聞いてみる
      コメントを追加
    2. Canon PowerShot SD450 LCD Screen Replacement: 手順 8、 1の画像 1
      • Remove the tripod mount screw.
      • Turn the camera around so that the screen is facing you, and the camera is upright.
      FixBotに聞いてみる
      コメントを追加
    3. Canon PowerShot SD450 LCD Screen Replacement: 手順 9、 1の画像 1
      • Remove the screw at the top right of the screen.
      FixBotに聞いてみる
      コメントを追加
    4. Canon PowerShot SD450 LCD Screen Replacement: 手順 10、 1の画像 1
      • Lift up the screen to reveal the tripod mount screw.
      FixBotに聞いてみる
      コメントを追加
    5. Canon PowerShot SD450 LCD Screen Replacement: 手順 11、 1の画像 1
      • Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
      FixBotに聞いてみる
      コメントを追加
    6. Canon PowerShot SD450 LCD Screen Replacement: 手順 12、 1の画像 1
      • Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Pierre Teplitxky
メンバー登録日: 04/10/10
152 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 25-85, Amido Spring 2010 Cal Poly, Team 25-85, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G85
4 メンバー
5のガイドは作成済み
3件のガイドコメント
Followed the steps and replaced the broken screen. Now I get only a white screen when turning the camera on. It does take pictures but it won't show anything but a little red dotted arrow on the right hand side over the white screen. Do you have a clue of what is happening?
Roberto - 返信 共有
Salve, dove posso acquistare un display?
Germano Tinari - 返信 共有
Salve, sapreste dirmi dove posso acquistare un display?
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 22
過去 30 日: 66
今までの合計 7,473
