メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot SD450 Flash Bulb
必要な工具と部品
  1. Canon PowerShot SD450 Flash Bulb, Casing: 手順 1、 1の画像 1
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
    FixBotに聞いてみる
    コメントを追加
  2. Canon PowerShot SD450 Flash Bulb: 手順 2、 1の画像 1
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
    FixBotに聞いてみる
    コメントを追加
  3. Canon PowerShot SD450 Flash Bulb: 手順 3、 2の画像 1 Canon PowerShot SD450 Flash Bulb: 手順 3、 2の画像 2
    • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
    FixBotに聞いてみる
    コメントを追加
  4. Canon PowerShot SD450 Flash Bulb: 手順 4、 1の画像 1
    • Take hold of the inside of the camera, and gently pull away from the back casing.
    FixBotに聞いてみる
    コメントを追加
  5. Canon PowerShot SD450 Flash Bulb: 手順 5、 1の画像 1
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
    FixBotに聞いてみる
    コメントを追加
  6. Canon PowerShot SD450 Flash Bulb: 手順 6、 1の画像 1
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
    FixBotに聞いてみる
    コメントを追加
  7. Canon PowerShot SD450 Flash Bulb, Motherboard: 手順 7、 1の画像 1
    • Remove the LCD cable by gently prying the hinge open with a spudger or your finger. The cable should easily slide out.
    FixBotに聞いてみる
    コメントを追加
  8. Canon PowerShot SD450 Flash Bulb: 手順 8、 1の画像 1
    • Lift up the metallic-colored clip with the spudger to remove the shutter panel.
    FixBotに聞いてみる
    コメントを追加
  9. Canon PowerShot SD450 Flash Bulb: 手順 9、 1の画像 1
    • Remove the shutter panel with the spudger, now that the clip is released.
    FixBotに聞いてみる
    コメントを追加
  10. Canon PowerShot SD450 Flash Bulb: 手順 10、 1の画像 1
    • Use the spudger or your finger to release the orange ribbon from the logic board.
    FixBotに聞いてみる
    コメントを追加
  11. Canon PowerShot SD450 Flash Bulb: 手順 11、 1の画像 1
    • Pull the ribbon out of the socket using the spudger or your finger.
    • Disconnect the two other ribbons from the logic board in the same fashion.
    FixBotに聞いてみる
    コメントを追加
  12. Canon PowerShot SD450 Flash Bulb: 手順 12、 1の画像 1
    • Lift up the large green flap by using the spudger to pry up top right yellow edge.
    FixBotに聞いてみる
    コメントを追加
  13. Canon PowerShot SD450 Flash Bulb: 手順 13、 1の画像 1
    • Pull the flap back with the spudger so that the logic board is exposed.
    FixBotに聞いてみる
    コメントを追加
  14. Canon PowerShot SD450 Flash Bulb: 手順 14、 1の画像 1
    • Use the screwdriver to remove the three screws on the logic board. Take note that the bottom right screw is shorter than the other two.
    FixBotに聞いてみる
    コメントを追加
  15. Canon PowerShot SD450 Flash Bulb: 手順 15、 1の画像 1
    • Use the spudger to carefully remove the logic board from behind.
    FixBotに聞いてみる
    コメントを追加
  16. Canon PowerShot SD450 Flash Bulb: 手順 16、 1の画像 1
    • Remove the detached logic board from the camera.
    FixBotに聞いてみる
    コメントを追加
  17. Canon PowerShot SD450 Flash Bulb, Flash Bulb: 手順 17、 1の画像 1
    • Remove the side screw holding the flash bulb.
    FixBotに聞いてみる
    コメントを追加
  18. Canon PowerShot SD450 Flash Bulb: 手順 18、 1の画像 1
    • Remove the orange ribbon from below the lens.
    FixBotに聞いてみる
    コメントを追加
  19. Canon PowerShot SD450 Flash Bulb: 手順 19、 1の画像 1
    この手順で使用する道具:
    • Grasp the plug that yellow and black wires are attached to, and gently remove. Tweezers are very helpful here.
    FixBotに聞いてみる
    コメントを追加
  20. Canon PowerShot SD450 Flash Bulb: 手順 20、 3の画像 1 Canon PowerShot SD450 Flash Bulb: 手順 20、 3の画像 2 Canon PowerShot SD450 Flash Bulb: 手順 20、 3の画像 3
    • Note that there is a capacitor in the flash bulb assembly, under the small circuit board. Do not touch the two metal terminals, as the capacitor may discharge. Damage and personal injury may result.
    • Use the spudger to carefully lift the flash bulb out.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Sean Whelan
メンバー登録日: 04/12/10
19 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 25-85, Amido Spring 2010 Cal Poly, Team 25-85, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G85
4 メンバー
5のガイドは作成済み
1件のガイドコメント
excellent a+!
Michelle - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 38
今までの合計 4,667
