メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot S100 LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot S100 LCD Screen Replacement, Outer Case: 手順 1、 3の画像 1 Canon PowerShot S100 LCD Screen Replacement, Outer Case: 手順 1、 3の画像 2 Canon PowerShot S100 LCD Screen Replacement, Outer Case: 手順 1、 3の画像 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
    FixBotに聞いてみる
    コメントを追加
  2. Canon PowerShot S100 LCD Screen Replacement: 手順 2、 1の画像 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
    FixBotに聞いてみる
    コメントを追加
  3. Canon PowerShot S100 LCD Screen Replacement: 手順 3、 3の画像 1 Canon PowerShot S100 LCD Screen Replacement: 手順 3、 3の画像 2 Canon PowerShot S100 LCD Screen Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
    FixBotに聞いてみる
    コメントを追加
  4. Canon PowerShot S100 LCD Screen Replacement, Control Dial Assembly: 手順 4、 1の画像 1
    • Turn the camera over so that the LCD screen is facing you.
    • Remove the screw (3.9mm, Phillips #00) that is attaching the thin metal frame to the camera.
    • Remove the 2 screws (3.1mm, Phillips #00) that are attaching the control dial panel to the camera.
    FixBotに聞いてみる
    コメントを追加
  5. Canon PowerShot S100 LCD Screen Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Using the tweezers, detach the ribbon cable that is connected to the dial panel.
    FixBotに聞いてみる
    コメントを追加
  6. Canon PowerShot S100 LCD Screen Replacement: 手順 6、 2の画像 1 Canon PowerShot S100 LCD Screen Replacement: 手順 6、 2の画像 2
    • Turn the camera over so that the lens is facing you.
    • Using the tweezers, gently lift the flap that is securing the ribbon cable to the motherboard.
    • Using the tweezers, remove the ribbon cable from its socket.
    FixBotに聞いてみる
    コメントを追加
  7. Canon PowerShot S100 LCD Screen Replacement: 手順 7、 1の画像 1
    • Gently pull the control dial panel, and its attached ribbon cable, through the opening between the top panel and the camera body.
    FixBotに聞いてみる
    コメントを追加
  8. Canon PowerShot S100 LCD Screen Replacement, LCD Screen: 手順 8、 1の画像 1
    • Remove the thin metal frame that runs along the top of the LCD screen.
    FixBotに聞いてみる
    コメントを追加
  9. Canon PowerShot S100 LCD Screen Replacement: 手順 9、 2の画像 1 Canon PowerShot S100 LCD Screen Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    • Using the tweezers, gently lift the flap that secures the ribbon cable to the motherboard.
    • Using the tweezers, detach the ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  10. Canon PowerShot S100 LCD Screen Replacement: 手順 10、 1の画像 1
    • Gently pull the LCD screen, and its attached ribbon cable, through the opening between the top panel and the camera body.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
12 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ricky
メンバー登録日: 02/23/15
975 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-4, Leahy Winter 2015 USF Tampa, Team 1-4, Leahy Winter 2015人のメンバー
USFT-LEAHY-W15S1G4
4 メンバー
5のガイドは作成済み
10件のガイドコメント
Thank you for this guide. I managed to strip one of the screws holding down the control dial and had to drill it out -- don't send a software engineer to do a hardware job :-) . I also found re-inserting the cables into the sockets pretty painful.
Overall it was a pretty easy fix. Your guide and $9 on eBay (http://r.ebay.com/jbyswX) saved me a $150 repair from Canon.
Thanks again.
Sriram Swaminarayan - 返信 共有
No wonder step 6 - the part that says 'gently lift the flap' is written in red. The 'flap' is glued onto the camera, and 'lifting' it simply breaks it off the camera, never to be returned. It was all going so well until this point; now I have to take/send it to an engineer and hope it can be fixed. I would ignore this part!
jasonmoran2307 - 返信 共有
Thank you for this excellent guide. I had a pressure popped LCD screen rendering the camera useless! However, your guide and £14.99 for an Amazon spare part, plus about 20 minutes following your guide and I have a fully working camera. Those ribbon cable are tricky though!
HowieB - 返信 共有
simplement bravo de France ! c’est excellent !
Be careful step 5 when you reconnect the ribbon to the dial. it may be misinserted (just under the right place and the screen won’t work.
tristan - 返信 共有
Step 5 seems simple but it is critical. I had a lens problem but I had to detach the screen. I managed to put the camera back together alright but when I was done the camera would work but the screen wouldn't come on. I finally read the remark on this page about step number 5 so I opened the back up and used some tweezers to detach the ribbon cable that is connected to the dial panel. Then looked closely and reattached the ribbon cable in exactly the right place. That was it! When I turned the camera on the LCD screen turned on as well. Thank you so much.
swlabr - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 107
今までの合計 5,053
