メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot G3 Zoom Control Spring Replacement
必要な工具と部品
    1. Canon PowerShot G3 Zoom Control Spring Replacement, Zoom Control Spring: 手順 1、 1の画像 1
      • Start by removing all of the screws around the camera: from the front, back, sides, and bottom.
      FixBotに聞いてみる
      コメントを追加
    2. Canon PowerShot G3 Zoom Control Spring Replacement: 手順 2、 1の画像 1
      • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
      FixBotに聞いてみる
      コメントを追加
    3. Canon PowerShot G3 Zoom Control Spring Replacement: 手順 3、 1の画像 1
      • Next remove the front and right side panels (the left side is attached to the front panel).
      FixBotに聞いてみる
      コメントを追加
    4. Canon PowerShot G3 Zoom Control Spring Replacement: 手順 4、 1の画像 1
      • Finally, remove the top panel as shown.
      FixBotに聞いてみる
      コメントを追加
    5. Canon PowerShot G3 Zoom Control Spring Replacement: 手順 5、 3の画像 1 Canon PowerShot G3 Zoom Control Spring Replacement: 手順 5、 3の画像 2 Canon PowerShot G3 Zoom Control Spring Replacement: 手順 5、 3の画像 3
      • With the top panel removed, locate the metal plate covering the zoom control on the underside of the panel (located on the forward left side, if the panel is oriented similarly to the first image.) This plate will also be connected to some circuit ribbon. Leave the ribbon attached to the plate.
      • Remove the screws from the plate, and lift and fold the plate along the attached circuit ribbon to the right (as shown in third image.)
      FixBotに聞いてみる
      コメントを追加
    6. Canon PowerShot G3 Zoom Control Spring Replacement: 手順 6、 2の画像 1 Canon PowerShot G3 Zoom Control Spring Replacement: 手順 6、 2の画像 2
      • With the top panel and metal plate removed, locate the zoom control on the underside of the panel (located on the forward left side if the panel is oriented similarly to the first image.) It will be located directly under the metal plate and circuit ribbon that was removed in the previous step.
      • Once the zoom control is located, remove the faulty zoom control spring from the metal pegs on the panel and zoom control.
      FixBotに聞いてみる
      コメントを追加
    7. Canon PowerShot G3 Zoom Control Spring Replacement: 手順 7、 2の画像 1 Canon PowerShot G3 Zoom Control Spring Replacement: 手順 7、 2の画像 2
      • Replace the zoom control spring with a comparable spring, attaching the loop ends to the same metal pegs to which the previous spring was attached (on the panel and zoom control.)
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Cory Jeanes
メンバー登録日: 11/07/15
101 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team 3-2, Kim Fall 2015 University of Memphis, Team 3-2, Kim Fall 2015人のメンバー
UM-KIM-F15S3G2
4 メンバー
34のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 33
今までの合計 1,096
