メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot A2300 Flash Assembly Replacement
必要な工具と部品
    1. Canon PowerShot A2300 Flash Assembly Replacement, Front Cover: 手順 1、 1の画像 1
      • Open the A/V Out Digital port cover on the function button side to reveal a screw.
      FixBotに聞いてみる
      コメントを追加
    2. Canon PowerShot A2300 Flash Assembly Replacement: 手順 2、 3の画像 1 Canon PowerShot A2300 Flash Assembly Replacement: 手順 2、 3の画像 2 Canon PowerShot A2300 Flash Assembly Replacement: 手順 2、 3の画像 3
      • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
      • Screws are small and very easily lost.
      FixBotに聞いてみる
      コメントを追加
    3. Canon PowerShot A2300 Flash Assembly Replacement: 手順 3、 2の画像 1 Canon PowerShot A2300 Flash Assembly Replacement: 手順 3、 2の画像 2
      • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
      • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
      FixBotに聞いてみる
      コメントを追加
    4. Canon PowerShot A2300 Flash Assembly Replacement: 手順 4、 1の画像 1
      • Gently lift the bottom of the front cover to roughly a 30 degree angle.
      FixBotに聞いてみる
      コメントを追加
    5. Canon PowerShot A2300 Flash Assembly Replacement: 手順 5、 1の画像 1
      • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
      FixBotに聞いてみる
      コメントを追加
    1. Canon PowerShot A2300 Flash Assembly Replacement, Back Cover: 手順 6、 1の画像 1
      • Hold the camera in your hands with both thumbs on the screen with the screen faced up.
      • Keep close to the table top in case the camera falls out of your hands.
      FixBotに聞いてみる
      コメントを追加
    2. Canon PowerShot A2300 Flash Assembly Replacement: 手順 7、 1の画像 1
      • Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
      • Do not completely remove the back cover by pulling on the side as shown. The cover is still attached on the top of the camera.
      FixBotに聞いてみる
      コメントを追加
    3. Canon PowerShot A2300 Flash Assembly Replacement: 手順 8、 1の画像 1
      • Pry the top off by sliding the spudger under the On/Off button.
      FixBotに聞いてみる
      コメントを追加
    4. Canon PowerShot A2300 Flash Assembly Replacement: 手順 9、 1の画像 1
      • Slide the cover to the right and off the camera.
      • Gently pry using the spudger on the right side if necessary.
      • The A/V OUT DIGITAL cover will sometimes become loose and disconnect from the cover
      FixBotに聞いてみる
      コメントを追加
    1. Canon PowerShot A2300 Flash Assembly Replacement, Flash Assembly: 手順 10、 1の画像 1
      • Raise the screen by wedging the spudger between the bottom of the screen and the mount hole.
      FixBotに聞いてみる
      コメントを追加
    2. Canon PowerShot A2300 Flash Assembly Replacement: 手順 11、 1の画像 1
      • Remove the metal sheet that is under the screen.
      FixBotに聞いてみる
      コメントを追加
    3. Canon PowerShot A2300 Flash Assembly Replacement: 手順 12、 1の画像 1
      • Remove the top left screw on the metal sheet that is behind the screen.
      • This screw connects the flash to the metal sheet.
      FixBotに聞いてみる
      コメントを追加
    4. Canon PowerShot A2300 Flash Assembly Replacement: 手順 13、 1の画像 1
      この手順で使用する道具:
      • Use one side of the tweezers to raise the orange retaining flap on the zero insertion force (ZIF) connector to a vertical position.
      FixBotに聞いてみる
      コメントを追加
    5. Canon PowerShot A2300 Flash Assembly Replacement: 手順 14、 1の画像 1
      • Gently pull the orange ribbon cable out of the ZIF connector using the tweezers.
      FixBotに聞いてみる
      コメントを追加
    6. Canon PowerShot A2300 Flash Assembly Replacement: 手順 15、 2の画像 1 Canon PowerShot A2300 Flash Assembly Replacement: 手順 15、 2の画像 2
      • Remove the flash by gently rotating slightly back and forth and pulling up.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nathan McMillan
メンバー登録日: 03/23/15
405 ポイント
2のガイドは作成済み
チーム
Baylor, Team 7-14, Williams Spring 2015 Baylor, Team 7-14, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G14
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 52
今までの合計 2,557
