メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon EOS Rebel T5 LCD Screen Replacement
必要な工具と部品
    1. Canon EOS Rebel T5 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
      • Lay the camera on its back so that the card/battery door is facing you.
      • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
      FixBotに聞いてみる
      コメントを追加
    2. Canon EOS Rebel T5 LCD Screen Replacement: 手順 2、 1の画像 1
      • Lift the now free card/battery door to reveal the battery compartment.
      • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
      FixBotに聞いてみる
      コメントを追加
    1. Canon EOS Rebel T5 LCD Screen Replacement, Back Cover: 手順 3、 1の画像 1
      • Turn the camera so that the back is facing to your right.
      • Remove the 5mm JIS #000 screw above the rubber USB port cover.
      FixBotに聞いてみる
      コメントを追加
    2. Canon EOS Rebel T5 LCD Screen Replacement: 手順 4、 1の画像 1
      • Remove the rubber piece.
      • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
      • It is held in place by a notched tether, but can be easily manipulated to slide out.
      FixBotに聞いてみる
      コメントを追加
    3. Canon EOS Rebel T5 LCD Screen Replacement: 手順 5、 1の画像 1
      • Turn your camera so that the bottom is facing you.
      • Remove the four 5mm JIS #000 screws.
      FixBotに聞いてみる
      コメントを追加
    4. Canon EOS Rebel T5 LCD Screen Replacement: 手順 6、 1の画像 1
      • Now turn the camera so that the front is facing towards your right.
      • Remove the two remaining 5mm JIS #000 screws.
      FixBotに聞いてみる
      コメントを追加
    5. Canon EOS Rebel T5 LCD Screen Replacement: 手順 7、 3の画像 1 Canon EOS Rebel T5 LCD Screen Replacement: 手順 7、 3の画像 2 Canon EOS Rebel T5 LCD Screen Replacement: 手順 7、 3の画像 3
      • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
      • Gently pry the back panel from the main body of the camera.
      • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
      • This back panel contains various control components of the camera as well as the LCD screen.
      FixBotに聞いてみる
      コメントを追加
    1. Canon EOS Rebel T5 LCD Screen Replacement, LCD Screen: 手順 8、 2の画像 1 Canon EOS Rebel T5 LCD Screen Replacement, LCD Screen: 手順 8、 2の画像 2
      • Remove the four silver 4mm JIS #000 screws connecting the LCD screen to the back of the camera.
      • Be sure to lift the ribbon cable to remove the remaining hidden black 4mm JIS #000 screw.
      FixBotに聞いてみる
      コメントを追加
    2. Canon EOS Rebel T5 LCD Screen Replacement: 手順 9、 1の画像 1
      • The LCD screen can now be lifted from the right side to be replaced.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Austin Tucker
メンバー登録日: 08/27/15
1,087 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015人のメンバー
USFT-WOLLERT-F15S16G4
4 メンバー
18のガイドは作成済み
8件のガイドコメント
This guide is NOT COMPLETE. THere are several missing screws that need to be removed.
2 from the viewfinder,
and 2 from the IO ports....
Do not follow this and force the back open or you will need more repair!
11romej - 返信 共有
Hi, I followed every step and replaced the LCD screen but when turned on the camera, I only got a yellow horizontal line. Do you know what could have gone wrong? Thank you.
Griselda Garcia - 返信 共有
Hi, excellent guide but I’ve a problem.
I’m need to buy a lcd display. Do you know where can I buy ? Can you recommend me one store to buy it?
Nicolás Morales - 返信 共有
@nickmorales I found the lcd display as well as the connected controller card ar eBay.
Tom Kane
Tom Kane - 返信 共有
I had problems connected the actual LCD component to the controller card, as seen in step 9. We need more illustrations for actually connecting the ribbon cables (plural!) and for actually mounting the LCD and the controller card.
Tom Kane
Tom Kane - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 88
今までの合計 9,992
