メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon EOS 6D Rear Body Panel Replacement
必要な工具と部品
    1. Canon EOS 6D Rear Body Panel Replacement, Rear Body Panel: 手順 1、 1の画像 1
      • Remove the viewfinder cover by pinching the sides and sliding it upward.
      FixBotに聞いてみる
      コメントを追加
    2. Canon EOS 6D Rear Body Panel Replacement: 手順 2、 1の画像 1
      • Open the battery door on the bottom of the camera.
      • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
      FixBotに聞いてみる
      コメントを追加
    3. Canon EOS 6D Rear Body Panel Replacement: 手順 3、 1の画像 1
      • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
      FixBotに聞いてみる
      コメントを追加
    4. Canon EOS 6D Rear Body Panel Replacement: 手順 4、 1の画像 1
      • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
      • Rotate the covers to the side so that you can see the connection ports inside.
      • Remove the following screws:
      • Two silver 5mm Phillips #00
      • One black 6mm Phillips #00
      FixBotに聞いてみる
      コメントを追加
    5. Canon EOS 6D Rear Body Panel Replacement: 手順 5、 1の画像 1
      • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
      FixBotに聞いてみる
      コメントを追加
    6. Canon EOS 6D Rear Body Panel Replacement: 手順 6、 1の画像 1
      • Rotate your camera so the bottom side is facing you.
      • One 6mm Phillips #00
      • Two 3mm Phillips #00
      FixBotに聞いてみる
      コメントを追加
    7. Canon EOS 6D Rear Body Panel Replacement: 手順 7、 1の画像 1
      • Rotate your camera so the back is facing you.
      • Three silver 5mm Phillips #00
      • Two black 6mm Phillips #00
      • One black 4mm Phillips #00
      FixBotに聞いてみる
      コメントを追加
    8. Canon EOS 6D Rear Body Panel Replacement: 手順 8、 2の画像 1 Canon EOS 6D Rear Body Panel Replacement: 手順 8、 2の画像 2
      • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
      • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
      • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
12 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Justin Thomas
メンバー登録日: 04/22/14
2,233 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 11-48, Amido Spring 2014 Cal Poly, Team 11-48, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G48
4 メンバー
20のガイドは作成済み
2件のガイドコメント
Thanks alot, very helpful
busulwa paddy - 返信 共有
Thanks alot, very helpful fixed an issue
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 67
今までの合計 11,011
