はじめに
If the flash does not fire after you have cleaned the hotshoe of your Canon EOS 40D or after you have attempted to lift the flash switch by passing a toothpick under the right side of the hotshoe, you may need to replace the entire hot shoe. Follow this guide to replace the flash hot shoe that matches Canon EOS 40D.
必要な工具と部品
Locate the battery compartment cover on the bottom of the camera below the shutter button.
Use a metal spudger or opening tool to gently lift the hotshoe plate and slide it off.
4 の人々がこのガイドを完成させました。
1件のガイドコメント
This is the best down to earth instructions i have ever had. No messing about even tells what screws and how to open the battery cover
Albert
