はじめに
Las carcasas Envoy Pro de OWC le permiten reutilizar un SSD Mac instalado de fábrica como una unidad externa portátil. Siga esta guía para aprender cómo instalar su SSD en la carcasa.
Si necesita completar la actualización de su SSD, busque su Mac a partir de this page y busque guía SSD Replacement.
Note: OWC Envoy Pro enclosures are designed for use with factory-installed Mac Solid State Drives, and will not work with other PCIe replacement drives and adapters, including OWC’s own Aura Pro drive.
必要な工具と部品
Para abrir el carcasa, tire de la mitad superior hacia el extremo en forma de cuña y levántelo para separarlo de la mitad inferior.
Una vez instalada la unidad, puede transfer data from it, or use Disk Utility to format it and use it as a Time Machine backup.
15 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Manuel Jesús Flores Jiménezさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
7 件のコメント
Does anyone know why the OWC Envoy Pro enclosure DOES NOT work with the OWC’s Aura Pro drive? I have noticed the warning (included above as well) that the enclosure only works with “factory-installed Mac Solid State Drives”. One would think that if the OWC Aura Pro drive can serve as a replacement for a Mac SSD that it should work in the Envoy Pro enclosure as well. The reason that I ask is that it would be much easier to format and transfer data to the Aura Pro drive via the enclosure rather than having to do this all after installation in the Mac computer.
I have OWC 480Gb SSD for MacBookAir mid 2012. I called OWC to ask the same question. I was told that it actually was a Heat matter, that it would work but at my own risk. I feel I was lucky to get that response and that they probably do not give it any more. I tried it with success, keeping the Enclosure lid open. I would not use it extensively though. For extra safety you can always use a small fan to cool it up. I think you can respect their recommandations by booting from the external enclosure with the original Mac SSD in it and then Clone it to the internal freshly formatted OWC SSD. I now have another OWC 480Gb SSD for MacBookAir 2015. Am I going to have the guts to also give it a try ? Just to play safe I will try not to. So I would suggest that a Heat Monitoring Program be installed and that both Original Apple and OWC SSD Temperature be monitored and compared.
12312312312312312
vasiliy -
I have one of these, and the SSD has gone bad. (Once connected, it randomly and quickly disconnects and reconnects.) So I'm planning on removing and trashing/destroying the old SSD. But then I have a perfectly good enclosure. Is this ONLY for MacBook SSDs, or are there other SSDs (etc) that would work with it to provide another external drive?
Hallo IFIXIT Team, ich hätte eine Frage. Ich habe eine original ssd aus einem MacBook Pro 2017 ausgebaut und möchte diesen in ein ext. Festplatten Gehäuse einbauen. Ich finde aber leider keine passendes Gehäuse das diese ssd lesen kann. Gibt es ein passendes ext. Gehäuse dafür?
Weniger anzeigen
