はじめに
Replacing the lightbulb involves opening up the machine. You will need to purchase a sewing machine bulb set, including the wire plug-in, to replace it.
必要な工具と部品
Place the machine on a solid surface.
Remove the 14mm Phillips #2 screw holding on the face cover.
ある他の人がこのガイドを完成しました。
