メインコンテンツにスキップ
Bose SoundTouch 20 Speaker Replacement
必要な工具と部品
  1. Bose SoundTouch 20  Speaker Replacement, Speaker: 手順 1、 2の画像 1 Bose SoundTouch 20  Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Remove the (6) six 1.5 cm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
    • Lift the cover straight up and set the cover to the side.
  2. Bose SoundTouch 20  Speaker Replacement: 手順 2、 2の画像 1 Bose SoundTouch 20  Speaker Replacement: 手順 2、 2の画像 2
    • Gently pull the white ribbon from the connector on the top side of the power board.
    • Make sure to pull straight back so you don't bend or damage the ribbon.
  3. Bose SoundTouch 20  Speaker Replacement: 手順 3、 2の画像 1 Bose SoundTouch 20  Speaker Replacement: 手順 3、 2の画像 2
    • Remove the (4) four 1.5 cm screws connecting the power board to the speaker.
    • Remove the (2) two 1 cm screws connecting the power board to the speaker.
    • When lifting the board, be careful of the two ribbons located underneath the board. Don't lift the board straight up, instead tilt it towards the cables. As shown in picture 2.
  4. Bose SoundTouch 20  Speaker Replacement: 手順 4、 2の画像 1 Bose SoundTouch 20  Speaker Replacement: 手順 4、 2の画像 2
    • Remove the white cable by pressing on the side of the connector with a tab and pulling backwards.
  5. Bose SoundTouch 20  Speaker Replacement: 手順 5、 2の画像 1 Bose SoundTouch 20  Speaker Replacement: 手順 5、 2の画像 2
    • Gently pull the thinner white ribbon located towards the center of the board.
    • Pull straight down to prevent bending or damaging the ribbon.
    • Squeeze the plastic sides of the plug and pull straight down to remove this ribbon.
    • After removing the two ribbons, completely remove the power supply board and set it to the side.
  6. Bose SoundTouch 20  Speaker Replacement: 手順 6、 2の画像 1 Bose SoundTouch 20  Speaker Replacement: 手順 6、 2の画像 2
    • To remove the side panel from the speaker, lift the top of the sides from the slots.
    • The sides will be bent up after removing from the slots, they do not come up right away.
    • After completing the previous step, pull gently straight up to remove the side.
    • Repeat on both sides of the speaker.
  7. Bose SoundTouch 20  Speaker Replacement: 手順 7、 3の画像 1 Bose SoundTouch 20  Speaker Replacement: 手順 7、 3の画像 2 Bose SoundTouch 20  Speaker Replacement: 手順 7、 3の画像 3
    • Remove the (2) two 1.5 cm screws circled in picture one.
    • Rotate the speaker to its side and remove the (2) two 1.5 cm screws circled in picture 2. Remove these screws on either side of the speaker.
    • After all screws are removed, gently remove the cover from the speaker as shown in picture 3.
  8. Bose SoundTouch 20  Speaker Replacement: 手順 8、 2の画像 1 Bose SoundTouch 20  Speaker Replacement: 手順 8、 2の画像 2
    • After lifting the cover, you will see two ribbons attaching the cover to the speaker. Gently remove these ribbons by pulling straight down.
    • Make sure to pull the ribbons straight out so you don't bend or damage the ribbon.
    If i want to oder a new cable what cable and pins i should order, if you know details please send me details to j_ramana@yahoo.com
    Venkata Ramana Jyothula - 返信
  9. Bose SoundTouch 20  Speaker Replacement: 手順 9、 1の画像 1
    • Remove the (14) fourteen 1 cm screws from the speaker.
    • Remove the (2) two 1.5 cm screws from the top left and right hand corners of the speakers, respectively.
  10. Bose SoundTouch 20  Speaker Replacement: 手順 10、 3の画像 1 Bose SoundTouch 20  Speaker Replacement: 手順 10、 3の画像 2 Bose SoundTouch 20  Speaker Replacement: 手順 10、 3の画像 3
    • Using a metal spudger or a prying tool, gently push forward to separate the cover from the speaker.
    Where I can buy the speakers, please
    faria34faray - 返信
  11. Bose SoundTouch 20  Speaker Replacement: 手順 11、 1の画像 1
    • Gently pull out the speaker from the placeholder by twisting and turning it.
    • The speaker is heavy and very magnetic.
    • Insert the replacement speaker by gently pushing it back into its place holder.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Samar Al mashrafi
メンバー登録日: 09/26/17
245 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S11-G3, Passmore Fall 2017 USF Tampa, Team S11-G3, Passmore Fall 2017人のメンバー
USFT-PASSMORE-F17S11G3
4 メンバー
10のガイドは作成済み
2 Guide Comments
hi, where can we find the speakers?
Rochlby Conan - 返信
Hi, where can i find the speaker
faria quitamba - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 101
今までの合計 8,353
