必要な工具と部品
Remove the (6) six 1.5 cm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
Lift the cover straight up and set the cover to the side.
After lifting the cover, you will see two ribbons attaching the cover to the speaker. Gently remove these ribbons by pulling straight down.
If i want to oder a new cable what cable and pins i should order, if you know details please send me details to j_ramana@yahoo.com
Using a metal spudger or a prying tool, gently push forward to separate the cover from the speaker.
4 の人々がこのガイドを完成させました。
2 件のコメント
hi, where can we find the speakers?
Hi, where can i find the speaker
