はじめに
If you notice any major damage to your charging port that prevents you from charging your device, you may need to replace your charging port.
必要な工具と部品
Remove the two 12.5 mm screws on either side of the charging port using a Torx T10 screwdriver.
8 の人々がこのガイドを完成させました。
15件のガイドコメント
Hello, This is an excellent resource. One thing, you did not say, or I did not see, where to purchase the actual usb port. Where can I locate one and this would be for a Bose Soundlink II.
Thank you,
Jim
jp7868@gmail.com
HI, thanks a lot for the instructions, any idea where i acn purchase the charging port full part
thanks
Carlos
I would like to know where i can buy the replacement part
Jeroen Knip - 返信 共有
Also would love to know where to purchase the required replacement MicroUSB Port. I'm searching and if I find anything compatible I will contact anyone else who posts to this thread.
