はじめに
The SoundLink Color's battery is known to lose charge after a few months of usage. This guide will show, step by step, how to take apart the device and replace the battery.
必要な工具と部品
この手順で使用する道具:Tweezers$4.99
Carefully remove the battery using a pair of tweezers.
Lift the inner assembly from the outer casing.
I opted for a Panasonic NCR18650B, choose the version with solder tabs, otherwise it will be a pain to solder wires on the battery and you'll probably go out from the factory dimensions. From the benchmarks it looks like a very good battery, time will tell.
Fit the new battery, cut the leads to the needed length, pay attention to polarity. You may need to enlarge leads holes in the plastic case with a cutter to let standard battery leads thru.
102 の人々がこのガイドを完成させました。
66件のガイドコメント
Any recommendations where to pick up/order a replacement battery from?
Rob Miller - 返信 共有
See the link in the description, it is available thru Amazon
Mine still works fine, but I'd like to know like the others here where to get a battery that will work as a replacement.
chandlerwebb - 返信 共有
