メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bose SoundDock Portable v2 Docking System Board Replacement
必要な工具と部品
    1. Bose SoundDock Portable v2 Docking System Board Replacement, Docking System Board: 手順 1、 1の画像 1
      • Lay the speaker flat on its back, balancing on the battery.
      • Remove the four rubber disks that cover the screws on the bottom of the speaker.
      • Follow the battery replacement guide to remove the battery
      FixBotに聞いてみる
      コメントを追加
    2. Bose SoundDock Portable v2 Docking System Board Replacement: 手順 2、 1の画像 1
      • Now, remove the four 16mm #2 screws on the bottom of the speaker. This will allow the bottom plate to be removed.
      • It may be easier to the remove the battery so that the speaker will lay flat on the table.
      FixBotに聞いてみる
      コメントを追加
    3. Bose SoundDock Portable v2 Docking System Board Replacement: 手順 3、 1の画像 1
      • Carefully remove the bottom panel of the speaker.
      • You may have to rock the panel back and forth to get it to slide off the plastic pegs.
      FixBotに聞いてみる
      コメントを追加
    4. Bose SoundDock Portable v2 Docking System Board Replacement: 手順 4、 1の画像 1
      • Once the panel is removed you will see a ribbon connecting the dock to the speaker. Be careful to orient the speaker so that you can work on the dock connector without pulling on the ribbon!
      FixBotに聞いてみる
      コメントを追加
    5. Bose SoundDock Portable v2 Docking System Board Replacement: 手順 5、 2の画像 1 Bose SoundDock Portable v2 Docking System Board Replacement: 手順 5、 2の画像 2
      • Use a T15 Torx screwdriver to remove the dock from the base. Be careful not to damage the ribbon during this step.
      • There is a torsion spring under the dock. When removed, this spring has a tendency to fly out. To avoid this, loosen the dock until it is able to move freely. Rotate it so that there is no tension in the spring. Then, you are free to undo the screw completely.
      FixBotに聞いてみる
      コメントを追加
    6. Bose SoundDock Portable v2 Docking System Board Replacement: 手順 6、 2の画像 1 Bose SoundDock Portable v2 Docking System Board Replacement: 手順 6、 2の画像 2
      • Remove the three 6mm T8 torques screws that hold the dock connector together and pull the top and bottom pieces apart.
      • There are some small parts that may fall out when the plastic pieces are separated. To minimize this, lay the piece with the dock connector facing down.
      FixBotに聞いてみる
      コメントを追加
    7. Bose SoundDock Portable v2 Docking System Board Replacement: 手順 7、 2の画像 1 Bose SoundDock Portable v2 Docking System Board Replacement: 手順 7、 2の画像 2
      この手順で使用する道具:
      • Once the pieces are separated, the dock connector can be lifted out of the slot.
      • Using tweezers or your fingers, unplug the two ribbon connectors from the board.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Evan Low
メンバー登録日: 04/14/15
584 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 4-1, Maness Spring 2015 Cal Poly, Team 4-1, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G1
4 メンバー
10のガイドは作成済み
2件のガイドコメント
How can I tell if it is my IPOD or the Bose system that needs to be repaired?
Ron Adams - 返信 共有
Where can I by this piece? I have to replace that piece.
PHelmut - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 31
過去 30 日: 107
今までの合計 23,214
