メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Boogie Board Rip Copper Button Plate Replacement
必要な工具と部品
  1. Boogie Board Rip Copper Button Plate Replacement, Accessing the internal components: 手順 1、 2の画像 1 Boogie Board Rip Copper Button Plate Replacement, Accessing the internal components: 手順 1、 2の画像 2
    • On the back of the device, remove the four 3/8" Torx head screws using the T-6 Torx bit.
    • A Torx bit is the piece that is inserted into a bit driver, also known as a screw driver.
    FixBotに聞いてみる
    コメントを追加
  2. Boogie Board Rip Copper Button Plate Replacement: 手順 2、 3の画像 1 Boogie Board Rip Copper Button Plate Replacement: 手順 2、 3の画像 2 Boogie Board Rip Copper Button Plate Replacement: 手順 2、 3の画像 3
    • Remove the stylus if it is in the housing at the top of the device.
    • Turn the device so you are looking at it from the top down.
    • Using your thumbs on each wall of the stylus housing, open the frame of the device by gently pulling the two sides apart.
    FixBotに聞いてみる
    コメントを追加
  3. Boogie Board Rip Copper Button Plate Replacement: 手順 3、 3の画像 1 Boogie Board Rip Copper Button Plate Replacement: 手順 3、 3の画像 2 Boogie Board Rip Copper Button Plate Replacement: 手順 3、 3の画像 3
    • Insert a spudger into the seam between the front and back plates of the frame. Unsnap the snaps around the entire frame of the device.
    • Remove the front face plate by pulling it straight up.
    • The unlock switch on the device's side might come off while undoing the internal snaps or removing the face plate. This is perfectly normal.
    FixBotに聞いてみる
    コメントを追加
  4. Boogie Board Rip Copper Button Plate Replacement: 手順 4、 2の画像 1 Boogie Board Rip Copper Button Plate Replacement: 手順 4、 2の画像 2
    • Use a spudger (or gently bend the back plate of the device) to unsnap the snaps holding the screen in place.
    FixBotに聞いてみる
    コメントを追加
  5. Boogie Board Rip Copper Button Plate Replacement: 手順 5、 2の画像 1 Boogie Board Rip Copper Button Plate Replacement: 手順 5、 2の画像 2
    • With a spudger, press against the lip of the connector closest to the wires to remove the battery connector from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Boogie Board Rip Copper Button Plate Replacement: 手順 6、 2の画像 1 Boogie Board Rip Copper Button Plate Replacement: 手順 6、 2の画像 2
    • Gently lift the motherboard with a spudger or small object by inserting it in the seam between the back frame and the motherboard.
    • Remove the battery hidden behind the motherboard.
    FixBotに聞いてみる
    コメントを追加
  7. Boogie Board Rip Copper Button Plate Replacement, Copper Button Plate: 手順 7、 2の画像 1 Boogie Board Rip Copper Button Plate Replacement, Copper Button Plate: 手順 7、 2の画像 2
    この手順で使用する道具:
    • Using tweezers gently go around the edges of the copper plate to remove the adhesive.
    FixBotに聞いてみる
    コメントを追加
  8. Boogie Board Rip Copper Button Plate Replacement: 手順 8、 2の画像 1 Boogie Board Rip Copper Button Plate Replacement: 手順 8、 2の画像 2
    • Use tweezers to grip the outer edge of the copper plate and lift the button straight off.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Gareth
メンバー登録日: 09/09/14
360 ポイント
3のガイドは作成済み
チーム
CSU Fullerton, Team 2-6, Bruce Fall 2014 CSU Fullerton, Team 2-6, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S2G6
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 37
今までの合計 2,989
