メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Blu Studio Selfie Midframe Replacement
必要な工具と部品
  1. Blu Studio Selfie Midframe Replacement, Rear Cover: 手順 1、 1の画像 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
    FixBotに聞いてみる
    コメントを追加
  2. Blu Studio Selfie Midframe Replacement: 手順 2、 1の画像 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
    FixBotに聞いてみる
    コメントを追加
  3. Blu Studio Selfie Midframe Replacement, Battery: 手順 3、 2の画像 1 Blu Studio Selfie Midframe Replacement, Battery: 手順 3、 2の画像 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
    FixBotに聞いてみる
    コメントを追加
  4. Blu Studio Selfie Midframe Replacement, Midframe: 手順 4、 1の画像 1
    • Remove all the 4mm Phillips #000 screws from the midframe.
    FixBotに聞いてみる
    コメントを追加
  5. Blu Studio Selfie Midframe Replacement: 手順 5、 1の画像 1
    • Insert the spudger between the midframe and the display assembly.
    • Gently pry up the midframe.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    FixBotに聞いてみる
    コメントを追加
  6. Blu Studio Selfie Midframe Replacement: 手順 6、 1の画像 1
    • Where the battery rested before, you will find a small clip that holds down the midframe.
    • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
    • Gently lift up on the clip until it comes free.
    • Remove the midframe from the phone.
    FixBotに聞いてみる
    コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Samuel McCandless
メンバー登録日: 01/20/16
170 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 10-1, Remmell Spring 2016 USF Tampa, Team 10-1, Remmell Spring 2016人のメンバー
USFT-REMMELL-S16S10G1
4 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 724
