メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Blu Dash 5.0 Dual SIM Display Cable Replacement
必要な工具と部品
  1. Blu Dash 5.0 Dual SIM Display Cable Replacement, Battery: 手順 1、 1の画像 1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
    FixBotに聞いてみる
    コメントを追加
  2. Blu Dash 5.0 Dual SIM Display Cable Replacement: 手順 2、 1の画像 1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
    FixBotに聞いてみる
    コメントを追加
  3. Blu Dash 5.0 Dual SIM Display Cable Replacement, Display Cable: 手順 3、 1の画像 1
    • Using the PH00 Phillips head screwdriver unscrew the screws holding the panel down, making sure to keep track of the position of the screws.
    • The screw holes with the red circle around them hold screws with a 3.5 mm length.
    • The screw holes with the orange circle around them hold screws with a 2.5 mm length.
    FixBotに聞いてみる
    コメントを追加
  4. Blu Dash 5.0 Dual SIM Display Cable Replacement: 手順 4、 2の画像 1 Blu Dash 5.0 Dual SIM Display Cable Replacement: 手順 4、 2の画像 2
    • Insert the plastic opening tool into a corner of the plastic panel and gently pry it away from the rest of the phone.
    • Do this for each corner until the panel pops up.
    FixBotに聞いてみる
    コメントを追加
  5. Blu Dash 5.0 Dual SIM Display Cable Replacement: 手順 5、 3の画像 1 Blu Dash 5.0 Dual SIM Display Cable Replacement: 手順 5、 3の画像 2 Blu Dash 5.0 Dual SIM Display Cable Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Along the right side of the phone you will see a long black wire with 2 gold end pieces on the end. This is the display cable.
    • To disconnect the gold end pieces from the motherboard, take the tweezers and gently but firmly pull upwards. Do this for both ends and the wire will disconnect.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Dashaya Toney
メンバー登録日: 10/27/14
876 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 4-7, Miles Fall 2014 UMass Dartmouth, Team 4-7, Miles Fall 2014人のメンバー
UMASSD-MILES-F14S4G7
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 28
今までの合計 3,391
