メインコンテンツにスキップ
Blink Video Doorbell Lens Replacement
必要な工具と部品
  1. Blink Video Doorbell Lens Replacement, Battery: 手順 1、 3の画像 1 Blink Video Doorbell Lens Replacement, Battery: 手順 1、 3の画像 2 Blink Video Doorbell Lens Replacement, Battery: 手順 1、 3の画像 3
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Lens Replacement: 手順 2、 3の画像 1 Blink Video Doorbell Lens Replacement: 手順 2、 3の画像 2 Blink Video Doorbell Lens Replacement: 手順 2、 3の画像 3
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Lens Replacement: 手順 3、 3の画像 1 Blink Video Doorbell Lens Replacement: 手順 3、 3の画像 2 Blink Video Doorbell Lens Replacement: 手順 3、 3の画像 3
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Lens Replacement, Back Panel: 手順 4、 3の画像 1 Blink Video Doorbell Lens Replacement, Back Panel: 手順 4、 3の画像 2 Blink Video Doorbell Lens Replacement, Back Panel: 手順 4、 3の画像 3
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell Lens Replacement, Lens: 手順 5、 3の画像 1 Blink Video Doorbell Lens Replacement, Lens: 手順 5、 3の画像 2 Blink Video Doorbell Lens Replacement, Lens: 手順 5、 3の画像 3
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell Lens Replacement: 手順 6、 2の画像 1 Blink Video Doorbell Lens Replacement: 手順 6、 2の画像 2
    • Carefully lift up the small daughterboard which contains the camera.
    • Remove two 5 mm screws from the back of the camera using a Phillips #0 screwdriver.
  7. Blink Video Doorbell Lens Replacement: 手順 7、 2の画像 1 Blink Video Doorbell Lens Replacement: 手順 7、 2の画像 2
    • Use tweezers to detach the white connector from the adapter on the motherboard.
    • Remove the lens.
終わりに
作成者
4人の作成者と共同で作成されました。
Kayla Crai
メンバー登録日: 10/18/24
495 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-1, Konn Fall 2024 UMass Dartmouth, Team 1-1, Konn Fall 2024人のメンバー
UMASSD-KONN-F24S1G1
4 メンバー
5のガイドは作成済み
コメント 1 件
Is it available to purchase the lens
William - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 38
過去 30 日: 123
今までの合計 395
