はじめに
The Blink Video Doorbell is a doorbell to provide extra security to your residence by giving you an accessible view whenever necessary. The lens is an added-on part of the device. It allows you to have a consistent, controllable, and color-accurate light source. Refer to the troubleshooting page if there are issues with the LED lights which could be connected to causes such as battery failure, software failure, and a frozen screen. If you need to take out the LEDs, use this guide to remove and replace the LEDs.
必要な工具と部品
Push the opening key into the small opening with the two gray buttons on the bottom of the device.
Push the device up from the mount and slide it off.
Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
Use an opening tool to release the motherboard from the device.
