メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Blackberry 8110 Display Replacement
必要な工具と部品
  1. Blackberry 8110 Display Replacement, Removing the back cover.: 手順 1、 2の画像 1 Blackberry 8110 Display Replacement, Removing the back cover.: 手順 1、 2の画像 2
    • Turn the phone over so that the screen is facing the table. Locate the chrome release button and push it in to unclip the battery cover.
    FixBotに聞いてみる
    コメントを追加
  2. Blackberry 8110 Display Replacement, Removing the screws.: 手順 2、 2の画像 1 Blackberry 8110 Display Replacement, Removing the screws.: 手順 2、 2の画像 2
    • Now that the battery cover has been removed, locate the two 7.5mm Torx #T6 screws at the top of the phone. Remove these by turning counter-clockwise with your T6 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  3. Blackberry 8110 Display Replacement, Removing the bottom cover.: 手順 3、 2の画像 1 Blackberry 8110 Display Replacement, Removing the bottom cover.: 手順 3、 2の画像 2
    • Now that the two screws at the top have been removed, take your spudger and locate the two gaps to the left and right of the button that releases the battery cover.
    • With your spudger, carefully wedge it into the gap and pry downwards to release the bottom cover.
    FixBotに聞いてみる
    コメントを追加
  4. Blackberry 8110 Display Replacement, Removng the screws from the front side.: 手順 4、 2の画像 1 Blackberry 8110 Display Replacement, Removng the screws from the front side.: 手順 4、 2の画像 2
    • Turn the phone over so that the screen is facing up. With the bottom cover off, you will be able to locate two 7.5mm Torx #T6 screws in each corner below the keyboard. Carefully remove these.
    FixBotに聞いてみる
    コメントを追加
  5. Blackberry 8110 Display Replacement, Taking off the side panels.: 手順 5、 2の画像 1 Blackberry 8110 Display Replacement, Taking off the side panels.: 手順 5、 2の画像 2
    • Now that the screws on the front have been removed, take your spudger and wedge it between the trim on the side of the phone, and the phone itself. Carefully pry the trim away from the phone.
    FixBotに聞いてみる
    コメントを追加
  6. Blackberry 8110 Display Replacement, Removing the back panel.: 手順 6、 2の画像 1 Blackberry 8110 Display Replacement, Removing the back panel.: 手順 6、 2の画像 2
    • You are now ready to remove the back panel. In order to do this, locate the two clips on each side of the phone (underneath the trim that you just removed).
    • Once you locate these clips (four in total, two on each side), you should be able to unclip them with your fingers.
    • Be gentle as to not break the clips in doing so.
    FixBotに聞いてみる
    コメントを追加
  7. Blackberry 8110 Display Replacement, Removing the front panel.: 手順 7、 2の画像 1 Blackberry 8110 Display Replacement, Removing the front panel.: 手順 7、 2の画像 2
    • The front panel is now ready to be removed from the rest of the phone. To do this, just pry the front part (with the keyboard and screen) away from the logic board of the phone with your fingers.
    FixBotに聞いてみる
    コメントを追加
  8. Blackberry 8110 Display Replacement, Disconnecting the display: 手順 8、 2の画像 1 Blackberry 8110 Display Replacement, Disconnecting the display: 手順 8、 2の画像 2
    • What is left after removing the panels is the logic board and screen. With the display facing up its connection to the logic board is on the top-left corner.
    FixBotに聞いてみる
    コメントを追加
  9. Blackberry 8110 Display Replacement: 手順 9、 3の画像 1 Blackberry 8110 Display Replacement: 手順 9、 3の画像 2 Blackberry 8110 Display Replacement: 手順 9、 3の画像 3
    • Swing the black tab securing the display cable outwards and away from the logic board to an upright position (perpendicular to the white block). The tab's pivot points are at the center-left and center-right of the white block.
    FixBotに聞いてみる
    コメントを追加
  10. Blackberry 8110 Display Replacement: 手順 10、 2の画像 1 Blackberry 8110 Display Replacement: 手順 10、 2の画像 2
    • Remove the display cable down towards the center of the logic board and away from under the black tab. Use a spudger between the display and logic board along all sides to separate the display.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Yaqoub Alshawaf
メンバー登録日: 09/25/14
201 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-2, Brown Fall 2014 USF Tampa, Team 1-2, Brown Fall 2014人のメンバー
USFT-BROWN-F14S1G2
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 43
今までの合計 666
