メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
BlackBerry R900M Logic Board Replacement
必要な工具と部品
    1. BlackBerry R900M Logic Board Replacement, Case Disassembly: 手順 1、 1の画像 1
      • Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
      FixBotに聞いてみる
      コメントを追加
    2. BlackBerry R900M Logic Board Replacement: 手順 2、 1の画像 1
      • Remove the backside of the device and set aside for later use.
      FixBotに聞いてみる
      コメントを追加
    3. BlackBerry R900M Logic Board Replacement: 手順 3、 2の画像 1 BlackBerry R900M Logic Board Replacement: 手順 3、 2の画像 2
      • Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
      FixBotに聞いてみる
      コメントを追加
    4. BlackBerry R900M Logic Board Replacement: 手順 4、 1の画像 1
      • Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
      FixBotに聞いてみる
      コメントを追加
    5. BlackBerry R900M Logic Board Replacement: 手順 5、 2の画像 1 BlackBerry R900M Logic Board Replacement: 手順 5、 2の画像 2
      • Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break.
      • Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
      • One is located below the scrollwheel.
      • Another is located behind the screen.
      FixBotに聞いてみる
      コメントを追加
    1. BlackBerry R900M Logic Board Replacement, Scroll Wheel: 手順 6、 2の画像 1 BlackBerry R900M Logic Board Replacement, Scroll Wheel: 手順 6、 2の画像 2
      • Pinch the white plastic clip that connects the ribbon of the scroll wheel to the logic board.
      • Gently wiggle and pull upwards to remove the scroll wheel.
      FixBotに聞いてみる
      コメントを追加
    1. BlackBerry R900M Logic Board Replacement, Display: 手順 7、 2の画像 1 BlackBerry R900M Logic Board Replacement, Display: 手順 7、 2の画像 2
      • Pull out the two black clips securing the screen’s ribbon so that they are as far out as they will go.
      • Gently remove the screen’s ribbon from the slot. Be sure to support the screen and any connected parts.
      FixBotに聞いてみる
      コメントを追加
    1. BlackBerry R900M Logic Board Replacement, External Battery Power Conductor: 手順 8、 1の画像 1
      • Disconnect the power conductor by gently peeling the grey section (which is connected to the logic board) upwards.
      FixBotに聞いてみる
      コメントを追加
    2. BlackBerry R900M Logic Board Replacement: 手順 9、 1の画像 1
      • The conductor can now be easily removed by pulling it off of the logic board.
      FixBotに聞いてみる
      コメントを追加
    1. BlackBerry R900M Logic Board Replacement, Internal Battery: 手順 10、 2の画像 1 BlackBerry R900M Logic Board Replacement, Internal Battery: 手順 10、 2の画像 2
      • Gently pull on the wires connecting the battery to the device until the battery disconnects.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Steven Jackowski
メンバー登録日: 04/18/10
1 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 33-83, Johann Spring 2010 Cal Poly, Team 33-83, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S33G83
4 メンバー
37のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 36
今までの合計 1,658
