メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
BlackBerry KeyONE partial Disassembly
必要な工具と部品
    1. BlackBerry KeyONE partial Disassembly, Remove top cover: 手順 1、 1の画像 1
      • Carefully remove the top plastic cover. It is held in place by adhesive.
      FixBotに聞いてみる
      コメントを追加
    2. BlackBerry KeyONE partial Disassembly, Remove top frame: 手順 2、 2の画像 1 BlackBerry KeyONE partial Disassembly, Remove top frame: 手順 2、 2の画像 2
      • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
      FixBotに聞いてみる
      コメントを追加
    3. BlackBerry KeyONE partial Disassembly, Remove back cover: 手順 3、 1の画像 1
      • Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
      FixBotに聞いてみる
      コメントを追加
    4. BlackBerry KeyONE partial Disassembly, Disconnect Battery: 手順 4、 2の画像 1 BlackBerry KeyONE partial Disassembly, Disconnect Battery: 手順 4、 2の画像 2
      • Remove the two Philipps #0 screws securing the battery connector and unplug the later.
      FixBotに聞いてみる
      コメントを追加
    5. BlackBerry KeyONE partial Disassembly: 手順 5、 1の画像 1
      • Remove the 6 Philipps #0 screws securing the lower cover and remove it.
      • Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
      FixBotに聞いてみる
      コメントを追加
    6. BlackBerry KeyONE partial Disassembly, Remove top cover: 手順 6、 1の画像 1
      • Remove the three Philipps #0 screws securing the upper cover and remove it.
      FixBotに聞いてみる
      コメントを追加
    7. BlackBerry KeyONE partial Disassembly: 手順 7、 1の画像 1
      • Unplug the remaining ribbon cables
      • Remove the last three Philipps #0 screws securing the Motherbard.
      • Now you should be able to replace most components.
      • The screen is held in place from the front by adhesive (or not, in the earlier versions), its cable slides trough the phone to the PCB - It's the large connector in the middle.
      • The battery is glued to the frame firmly. There are three pultabs located underneath the motherboard.
      • Don't forget to remove the sim-tray if you're removing the motherboard.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
15 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
raven
メンバー登録日: 09/02/15
1,110 ポイント
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 77
今までの合計 10,979
