はじめに
How to disassemble your Benchmade Griptillian
必要な工具と部品
Be sure to make note of what side the belt clip is on for reassembly.
Turn the knife over and remove the T8 screw that is going through the hinge.
Using the T6 bit, drive the hinge pin out of the other handle.
Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
3 の人々がこのガイドを完成させました。
