メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Beats Studio 2.0 Ear Pads Replacement
必要な工具と部品
ビデオの概要
  1. Beats Studio 2.0 Ear Pads Replacement, Detach the old cushionDetach: 手順 1、 1の画像 1
    • Grab a butter knife and start separating the cushion from the headphones. We must warn you not to use anything sharper than a butter knife, it can damage your headphones as well as have the potential for injury.
    FixBotに聞いてみる
    コメントを追加
  2. Beats Studio 2.0 Ear Pads Replacement, Clean the remaining adhesive: 手順 2、 1の画像 1
    • It is very important that you clean the remaining adhesive! If you have any remaining adhesive, there will be a weird gap in-between the headphones and the cushions. You can even use an alcohol wipe to remove the adhesive. The bottom line is, the cleaner the surface, the better the ear pads will stick!
    FixBotに聞いてみる
    コメントを追加
  3. Beats Studio 2.0 Ear Pads Replacement, Grab your replacement right side cushion: 手順 3、 1の画像 1
    • You will see that the right side cushion is the cushion with a gap where the USB port should be. These are not an ordinary cushions, they have an extremely strong and thick adhesive that is crucial for this process to work.
    FixBotに聞いてみる
    コメントを追加
  4. Beats Studio 2.0 Ear Pads Replacement, Prepare the adhesive: 手順 4、 1の画像 1
    • To make it easier for you to peel the adhesive, take a sharp knife and make a small cut on the surface. BEFORE you peel the adhesive, read the next step!
    FixBotに聞いてみる
    コメントを追加
  5. Beats Studio 2.0 Ear Pads Replacement, Align the holes with dowels on the headphones: 手順 5、 1の画像 1
    • There are two dowels on the headphone, on the top left and the bottom right. You can get a better understanding of how to apply the cushion to the headphones before peeling the adhesive.
    FixBotに聞いてみる
    コメントを追加
  6. Beats Studio 2.0 Ear Pads Replacement, Peel the adhesive & attach the ear pads: 手順 6、 1の画像 1
    • So take your ear pad and align the top dowel to the hole, push it in, and then align the bottom one. Apply pressure on the ear pads for a good minute that way you remove any gaps. If you have noticeable gaps, that means you have not aligned the cushion correctly and try again.
    FixBotに聞いてみる
    コメントを追加
  7. Beats Studio 2.0 Ear Pads Replacement, Condition: 手順 7、 1の画像 1
    • The last most important step! Apply constant pressure on the ear pads by taking a couple of books and putting the headphones on them in a way that applies the most pressure without bending the headphone headband to far. We hope you enjoyed this simple tutorial, if you have any questions, do not hesitate to contact us.
    FixBotに聞いてみる
    コメントを追加
  8. FixBotに聞いてみる
    コメントを追加
終わりに
To replace your cushions , please follow the next steps .
キャンセル: このガイドを終了できませんでした。
11 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Wicked Cushions
メンバー登録日: 03/31/17
307 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 66
過去 30 日: 308
今までの合計 102,967
