メインコンテンツにスキップ
Beats Studio 2 Wireless Speaker Replacement
必要な工具と部品
  1. Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: 手順 1、 2の画像 1 Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: 手順 1、 2の画像 2
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
  2. Beats Studio 2 Wireless Speaker Replacement: 手順 2、 3の画像 1 Beats Studio 2 Wireless Speaker Replacement: 手順 2、 3の画像 2 Beats Studio 2 Wireless Speaker Replacement: 手順 2、 3の画像 3
    • Pull the rest of the cushion away from the adhesive with your hands.
  3. Beats Studio 2 Wireless Speaker Replacement, Speaker: 手順 3、 2の画像 1 Beats Studio 2 Wireless Speaker Replacement, Speaker: 手順 3、 2の画像 2
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
  4. Beats Studio 2 Wireless Speaker Replacement: 手順 4、 1の画像 1
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
  5. Beats Studio 2 Wireless Speaker Replacement: 手順 5、 2の画像 1 Beats Studio 2 Wireless Speaker Replacement: 手順 5、 2の画像 2
    • Gently pull the wire with rubber connectors off of the speaker.
  6. Beats Studio 2 Wireless Speaker Replacement: 手順 6、 1の画像 1
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
終わりに
After soldering the new speaker, reassemble your device by following the steps in reverse order.
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mike Rosiello
メンバー登録日: 03/20/23
313 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023人のメンバー
UMASSD-RAMOS-S23S5G3
3 メンバー
4のガイドは作成済み
コメント 1 件
I didn't need to replace a speaker but just touch up the solder joints, this was a great guide! Thank you!
William Pryor - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 22
今までの合計 278
