メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Basic Maintenance
必要な工具と部品
  1. Basic Maintenance, Locating the side panel: 手順 1、 2の画像 1 Basic Maintenance, Locating the side panel: 手順 1、 2の画像 2
    • First, locate the side panel on the far left side of your board.
    • Then, flip your board upside down.
    • Make sure your console is resting on a towel or soft surface, as hard jolts or bumps can cause damage to your board.
    FixBotに聞いてみる
    コメントを追加
  2. Basic Maintenance, Removing the bracket: 手順 2、 2の画像 1 Basic Maintenance, Removing the bracket: 手順 2、 2の画像 2
    • Now, use your Phillips-head screwdriver to unscrew the two screws holding the bracket on.
    • Then flip your board over and do the same on the other side to remove the second bracket.
    FixBotに聞いてみる
    コメントを追加
  3. Basic Maintenance, Loosening the panel screws: 手順 3、 1の画像 1
    • Now, locate the three screws at the bottom of the back panel and loosen them approximately two full turns.
    • Make sure to keep screws separate! Always label and separate different screws to avoid confusion when we reassemble the board.
    FixBotに聞いてみる
    コメントを追加
  4. Basic Maintenance, Remove the metal pieces: 手順 4、 1の画像 1
    • Now flip your board over again so it is right-side-up.
    • Then, remove the seven screws holding the metal piece on with the same screwdriver. There is one screw to the far right of the piece that I could not fit into the photo.
    FixBotに聞いてみる
    コメントを追加
  5. Basic Maintenance, Pull the top off: 手順 5、 2の画像 1 Basic Maintenance, Pull the top off: 手順 5、 2の画像 2
    • Now, put your hand on the back of the board and lift up and away from the base of the console. Be careful of any wires!
    • Set the top panel next to the base to avoid wires getting tangled and broken.
    FixBotに聞いてみる
    コメントを追加
  6. Basic Maintenance, The inside components: 手順 6、 2の画像 1 Basic Maintenance, The inside components: 手順 6、 2の画像 2
    • You might notice that a lot of the components inside the lighting board look similar to those of a desktop computer. The power supply, hard drive, RAM, CPU, and cooling system are all in the base of the board.
    • If you have a compressed air can or blower, use that to clean the main components, especially around the CPU and heatsinks, as these can get clogged with dust and debris. If you don't have one of these tools, use a DRY paper towel or tissue to gently wipe down the components.
    FixBotに聞いてみる
    コメントを追加
  7. Basic Maintenance, Re-seating the RAM: 手順 7、 2の画像 1 Basic Maintenance, Re-seating the RAM: 手順 7、 2の画像 2
    • RAM is good to re-seat every so often, as it helps to maintain clean ports and fast memory speeds.
    • To remove the RAM, press down on the two clips on either side of the stick, then pull up on the RAM to remove it.
    • Once you remove it, you can take your air blower and gently blow off any dust on the connectors and memory cards.
    FixBotに聞いてみる
    コメントを追加
    • Now reverse these steps to reassemble your ETC Ion 1000!
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
someperson
メンバー登録日: 02/11/26
953 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 26
今までの合計 83
