メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
BOSE SoundTouch 30 Subwoofer Replacement
必要な工具と部品
    1. BOSE SoundTouch 30 Subwoofer Replacement, Base Plate: 手順 1、 2の画像 1 BOSE SoundTouch 30 Subwoofer Replacement, Base Plate: 手順 1、 2の画像 2
      • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
      FixBotに聞いてみる
      コメントを追加
    1. BOSE SoundTouch 30 Subwoofer Replacement, Power Supply: 手順 2、 1の画像 1
      • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
      FixBotに聞いてみる
      コメントを追加
    2. BOSE SoundTouch 30 Subwoofer Replacement: 手順 3、 2の画像 1 BOSE SoundTouch 30 Subwoofer Replacement: 手順 3、 2の画像 2
      • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
      • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
      FixBotに聞いてみる
      コメントを追加
    3. BOSE SoundTouch 30 Subwoofer Replacement: 手順 4、 1の画像 1
      • Remove all four 15.5 mm PH2 screws holding the power supply down.
      • The power supply is identified by a green board with a large metal covering.
      FixBotに聞いてみる
      コメントを追加
    4. BOSE SoundTouch 30 Subwoofer Replacement: 手順 5、 2の画像 1 BOSE SoundTouch 30 Subwoofer Replacement: 手順 5、 2の画像 2
      • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
      • Pick up the power supply and remove the fourth cable from the underside of the power supply.
      • Remove the power supply.
      FixBotに聞いてみる
      コメントを追加
    1. BOSE SoundTouch 30 Subwoofer Replacement, Motherboard: 手順 6、 3の画像 1 BOSE SoundTouch 30 Subwoofer Replacement, Motherboard: 手順 6、 3の画像 2 BOSE SoundTouch 30 Subwoofer Replacement, Motherboard: 手順 6、 3の画像 3
      • Remove the five 15.5 mm PH2 screws holding the motherboard down.
      • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
      • Remove the motherboard.
      • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
      FixBotに聞いてみる
      コメントを追加
    1. BOSE SoundTouch 30 Subwoofer Replacement, Subwoofer: 手順 7、 1の画像 1
      • Remove the eight 15.5 mm PH2 screws holding the plastic insert down.
      • Remove the plastic insert.
      FixBotに聞いてみる
      コメントを追加
    2. BOSE SoundTouch 30 Subwoofer Replacement: 手順 8、 1の画像 1
      • Remove the three 15.5 mm PH2 screws holding the metal insert down.
      • Remove the metal insert.
      FixBotに聞いてみる
      コメントを追加
    3. BOSE SoundTouch 30 Subwoofer Replacement: 手順 9、 1の画像 1
      • Remove the three 19 mm PH2 screws holding the metal subwoofer cover down.
      • Remove the subwoofer cover.
      FixBotに聞いてみる
      コメントを追加
    4. BOSE SoundTouch 30 Subwoofer Replacement: 手順 10、 1の画像 1
      • Remove the four 19 mm PH2 screws holding the subwoofer in place.
      • Be careful not to let the screwdriver slip and damage the fragile subwoofer.
      FixBotに聞いてみる
      コメントを追加
    5. BOSE SoundTouch 30 Subwoofer Replacement: 手順 11、 2の画像 1 BOSE SoundTouch 30 Subwoofer Replacement: 手順 11、 2の画像 2
      • Remove the subwoofer by pulling towards the back of the device while tucking the wire under the plastic enclosure.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brennen Irey
メンバー登録日: 04/18/18
1,269 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S16-G2, Livingston Spring 2018 Cal Poly, Team S16-G2, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S16G2
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 30
今までの合計 5,644
