はじめに
This guide will help you access and replace the Axess TA2513-10WT camera by following this procedure. It's possible that your camera is broken or malfunctioning or the tablet isn't producing any image due to physical damage to the lens or software bugs causing compatibility issues. Whatever your motivation, following this beginner's guide shouldn't take more than 30 minutes and doesn't require any prior repair knowledge. Before attempting to fix your tablet, please make sure you turn it off.
必要な工具と部品
Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
Turn the tablet over. Locate the left screw.
Use the magnetic screwdriver to remove the left screw.
